Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
#11 |
#12 |
Active sub taking signal from the FR's amp's output? Taking signal from the same source as the amp? Or a big woofer with a passive crossover hanging off the same amp as the FR?
#13 | |
:)ensen.
Those who claim to be making history are often the same ones repeating it. |
#14 |
With the right enclosure volume a series cap is sufficient. The formulas are in post 4, ideal Qtb is 0,93
GHP Berechnung, Lautsprecher - HIFI-FORUM |
#15 | |
speaker out, A= FRs B= sub. no worries, its all good, the primary user has common sense, and im reasonably sure the system will get loud enough to make most people want to turn it down, before reaching the FRs critical point. |
#16 |
Did it Himself
Fuses do almost nothing to protect against excess low frequency. Also many claim they sound bad
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more. |
#17 | |
only if they're not gold plated or installed backwards
kinda burnt out - taking a break |
#18 |
"A= FRs
B= sub. no worries, its all good, the primary user has common sense, and im reasonably sure the system will get loud enough to make most people want to turn it down" Excellent advice there. When you turn the bass down (to make up for the extra bass in the woofs/subs), you also reduce the excursion of the full range driver (less gargle/straining and more dynamics/volume). A win win situation. Norman |
#19 |
I tried big motor runs as a speaker level high pass, but for a woofer crossover at 165ish (which is, I assume, higher than you are thinking). They cost a few bucks, but didn't sound too bad. I could hear them, though. I am using a line level cap, as others recommended. You could probably build a single chip preamp for the same price as the motor runs (easy too, with all the 'cmoy' pcbs floating around), which would allow the passive line level, provided you can also run your sub amp with a line level input.
Paul Wild Burro Audio Labs - DIY Full Range Speakers |
Thread | Thread Starter | Forum | Replies | Last Post |
Show us how you Protect your beloved MOSFET Driver IC | Reactance | Class D | 0 | 19th April 2010 03:14 PM |
Need Comments on FR Bass Reflex | blip1882 | Full Range | 11 | 28th September 2005 05:48 AM |
How to figure FR with bass boost? | Dave Jones | Multi-Way | 35 | 7th June 2004 06:34 PM |
New To Site? | Need Help? |
