Room Walls as waveguides?
Old 1st May 2011, 04:44 PM   #1
60ndown is offline 60ndown  United States
Default Room Walls as waveguides?
Has anyone ever tried mounting a driver/s to a baffle, and mounting that baffle into the corner of the room on the wall, so the corner of the room is the box and the walls themselves become a wave guide?
im want to fill a 'whole room' with sweet full range sound, not have 1 dedicated listening position with a 3D image.
any thoughts on my "corner mounted wave guide" idea?
Old 1st May 2011, 05:10 PM   #2
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Take a look at William's web-site for a similar idea.
William Cowan's Homepage
Look at the Unity, the Finale
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 1st May 2011, 05:21 PM   #3
cool thanks
Soffit mounting is a technique used regularly in recording studios. It eliminates the baffle step associated with having a pair of speakers sitting out in the room. The radiation angle at low frequencies is confined to 90 degrees in the horizontal plane. The Unity horns also have a radiation angle which is around 90 degrees at the crossover frequency, narrowing to 60 degrees up higher. Having a speaker system with essentially the same radiation angle at all frequencies guarantees a flat power response. This can clearly be heard when walking around the listening room, and indeed the whole house. Apart from a reduction in exteme treble, the sound essentially doesn't change as you walk around the house.
Old 1st May 2011, 06:01 PM   #4
im doing it with CSS el70s and a sub
Old 1st May 2011, 07:06 PM   #5
c2cthomas's Avatar
Yeh - I have bad dreams about doing something like William has done - and then a few months later SWMBO sez - honey - I want to rearrange the furniture.
Old 1st May 2011, 07:17 PM   #6
wouldnt matter
"This can clearly be heard when walking around the listening room, and indeed the whole house. Apart from a reduction in exteme treble, the sound essentially doesn't change as you walk around the house"
do it
Old 1st May 2011, 08:14 PM   #7
c2cthomas's Avatar
wouldnt matter
1) I'm not sure if you are familiar with GRITS - Girls Raised In The South
2) I'm pretty sure that you are not familiar with SWMBO - born and bred in Nashville + is a spoiled Doctors brat.
3) The combination of #1+ #2 is - hmmmmmmm - let me say that it can represent a considerable challenge to counter on a long term basis. AND there WILL BE payback involved at some point. Fortunately for me I am at and older and wiser point in my life where I don't give a rat's behind.
Old 1st May 2011, 10:06 PM   #8
hump??...what hump?
Old 1st May 2011, 10:47 PM   #9
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
When I read "Soffit mounting" I was expecting something totally different, these are not soffit mounted at all, but still cool nonetheless
Soffit - Wikipedia, the free encyclopedia
Old 2nd May 2011, 12:44 AM   #10
chrisb is offline chrisb
and they keep us around, even after our gamete donation to the future generation - perhaps it's pity / charity?
kinda burnt out - taking a break
Room Walls as waveguides?Hide this!Advertise here!
Black Hole in your listening room; room treatment dfidler Everything Else 5 29th March 2011 01:02 AM
basic room accoustics..help design my ht room :) JinMTVT Multi-Way 4 4th September 2007 12:35 PM
Replacing room walls with MDF or Particle Board? Hybrid fourdoor Everything Else 5 2nd April 2004 02:46 PM
5 inch walls? amo Multi-Way 27 13th January 2004 04:41 AM
non-parallel walls sangram Multi-Way 14 7th April 2003 09:13 AM
