What FR $250 pair, driver works best in a bookshelf sized speaker? - Page 2 - diyAudio
Old 30th April 2011, 10:15 PM   #11
DYNABLASTERTUNERS's Avatar
I measure, NOT!
Yes I've tested them with my ears and listened to them as nearfeld PC Loudspeakers about a month or so, active crossover at about 300-400hz plus kickbass on the floor, and they sound very non fatiquing, but they don't miss any details, also good HF, and vocals are scary realistic, for that money I really don't know what could compete with them (except maybe the Bamboo cones, but I havent heard them yet, altough they're waiting here ready steady )
here's my suboptimal test arrangement, it's just for quick & dirty learning what personality the tested Widerangers have, because I have many and now I just try them in this way, I apologize for the pics and mess
some of my Designs www.dynablaster.deviantart.com/gallery
Old 30th April 2011, 10:37 PM   #12
frugal-phile(tm)
planet10's Avatar
I bet EL70 give them a run...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th April 2011, 11:15 PM   #13
can be possible, but Tang Bands have some magic that can't be explained with words
TBs I've listened:
rare OEM W3-823, very stunning real focusing and details, action, but needs a notch between 4-5kHz, those are bargain if you are a notch fun(I like them much more than Alpair 6 gen.1- because a lack of HF, etc.)
silver W3-871, absolute unrealistic and unbalanced, what is oposite from they hype, I don't like this speaker because it has no intimacy and TB magic, to me it sounds flat and fabricated
those 5" polypropilene cone, big cone for a 5"!, mellow and realistic, TB magic is there- but some smaller are better in this, no need for supertweeter, but you can add the rearfiring supertweeter ambience ennhancer , vocals are remarkable and drag you into the dimension of sweetness supersound 3D+ hehe
and flat w3-1797- those are unreal, my favourite, for tehno I dont know- maybe the ultimate widerangers on planet 4 electro music those immense high frequencies, they shower you with sound and the whole room is one big soundstage, not just in front of you or left right, those change the thickness of air, and throw a dimension that is unbeleivable, they are just funny how good they are
Old 1st May 2011, 04:58 AM   #14
60ndown is offline 60ndown  United States
hmmm, tang band or css? given i dont use computer software to design boxes, and ill likely be building sealed boxes, which one of these 2 drivers will perform best in a sealed box ?
and if they perform about equally, which one will get louder and remain least fatiguing?
tang band is 25 wrms, i dont see a power handling number on the css site for the el70?
25 watts seems weak to me, i recently played with this
https://www.madisound.com/store/prod...roducts_id=843
and liked it a lot, very warm sounding with recessed mids and highs, and 60 watts ...
it has an 8" brother
https://www.madisound.com/store/prod...roducts_id=848
efficiency is amazing, might not even need a sub?
http://www.decware.com/newsite/DM945.html
Old 1st May 2011, 05:15 AM   #15
frugal-phile(tm)
planet10's Avatar
Power handling is more or less irrelevant.
I haven't seen a lot of designs for the TB, but there are lots & lots of proven cabinets for the EL70. Not many drivers designed for sealed boxrs these days.
p10 hifi | Box Library / CSS
dave
Old 1st May 2011, 01:29 PM   #16
dave
doesnt power handling and efficiency determine volume ability?
dont all drivers work very in a well sealed box?
sealed boxes mean no phase issues with ports/vents and rear waves right?
Old 1st May 2011, 02:41 PM   #17
In my limited experience, (and over-generalizing a bit), for a given driver, sealed will mean a higher cutoff (does not play as low). It also may mean higher excursion so that puts a limit on maximum SPL. It's easier to get "right" (i.e., to avoid misalignments). The smoother 12db/octave rolloff may blend better with room gain, and may sound "cleaner" because it's simpler.
For that same driver (in general), ported can play lower with less excursion. The roll-off is steeper, and the driver is at risk below the box tuning frequency (nothing damps it). And many commercial ported boxes (at Best Buy etc.) are woefully, horribly misaligned due to either poor design, or poor quality control on the drivers, or other factors.
But either design can be done correctly and sound good. The main problem I have with ported is if you tune it to maximize bass extension, it -may- sound "less clear" than sealed or horn. So the answer is simply to tune it higher and accept less quantity for higher quality. It's very room-dependent in the end.
Old 1st May 2011, 04:33 PM   #18
frugal-phile(tm)
planet10's Avatar
It would but there is no standard for measuring power handling, so nothing to compare. Also, you invariably run out of power before the driver runs out.
Most drivers made today have T/S optimized for some sort of vented enclosure,
|In a sealed enclosure they will have less group delay & a slower roll-off, but usually insufficient bass to keep people happy.
Unfortunately the 1 driver that did quite well sealed, the MA CHR70.2, turned out more popular than anyone planned for and they sold out months ago, with the next ones probably still 6-8 weeks away.
dave
Old 1st May 2011, 04:47 PM   #19
CSS EL70s ordered (i trust the build house/ QC more then tang band)
will be using the walls as wave guides.
Room Walls as waveguides?
and a sub
thanks for the help/advice/guidance.....
Old 2nd May 2011, 09:11 AM   #20
diyAudio Member RIP
a) only in the midrange, for bass volume displacement determines max volume.
b) all drivers can work in a sealed box of some sort, doesn't mean they should be.
c) The EL70 parameters indicate a smallish sealed well stuffed box.
A subwoofer will be needed to produce realistic low bass levels.
rgds, sreten.
Best FR Size for Small/Medium Sized Room wushuliu Full Range 13 5th October 2010 10:26 PM
Pair Dale 250 watt / 8 ohm test Resistors Badge Swap Meet 1 21st August 2008 11:04 PM
Very large sized planar driver ( 180square feet) ...possible ? JinMTVT Multi-Way 33 13th November 2007 05:51 AM
smallest sized, efficient bookshelf speakers for the Charlize? hansel Multi-Way 3 11th April 2007 11:15 PM
Need help with choosing speaker driver for bookshelf project sumacSK Multi-Way 1 11th February 2007 04:54 PM
Copyright 1999-2017 diyAudio
