Ideas on Internal Wiring for Saburo - Page 7 - diyAudio
Old 24th May 2011, 09:14 PM   #61
chrisb is offline chrisb  Canada
Originally Posted by planet10 View Post
Yep, those are the ones. To keep the cost down, there is very little metal in them. Lite on bling, hi on performance.
dave
actually, I prefer the soft plastic with strain relief / grip
Phono Plug (4-Pack) - RadioShack.com
but you get the idea - not blingy - not the most noble or expensive materials, but very little of them
of course at the other extreme, the Eichmann bullet plugs sound very nice, but are designed for much thicker jacketed cable - easily remedied by wrapping your conductors around some food rated vinyl tubing and a layer of self adhesive shrink wrap tubing
... so, not as easy at it sounds, this letting go thing
Old 24th May 2011, 09:24 PM   #62
qusp is offline qusp  Australia
qusp's Avatar
there are also rubber grommets produced by eti that allow much thinner conductors to be used without forgoing strain relief. cant say i've seen them available at any of the resellers, but you can get them direct
Old 6th June 2011, 03:06 PM   #63
von Ah is offline von Ah  United States
von Ah's Avatar
What sort of binding posts are you guys (Dave, Chris, zman01) using with 24g solid copper? Are you using bananas? Do you have recommendations?
Marc
Old 6th June 2011, 03:34 PM   #64
zman01 is offline zman01  Bangladesh
Marc
Marc,
I am using banana plugs. And for binding posts I am using something similar to this:
http://www.amazon.com/Round-Speaker-.../ref=pd_cp_e_1
Please note that these are quite small and the hole into the side wall is approx 50mm - smaller than other 75-76mm cups - recommended by none other than Chrisb.
Also please note on the banana plus and RCA connectors Planet10 (Dave and Chris) recommend ones made of relatively thin metal.
-Zia
Old 6th June 2011, 03:41 PM   #65
von Ah's Avatar
Thanks, Zia. I'm closing in on the minimal metal philosophy.
Old 6th June 2011, 04:39 PM   #66
regarding speaker / amp connections, while theoretically "no plug" would be the best method, in practice I like to use these Pomona double plugs for ease of use and dirt cheap price
first picture I could find on-line - these come in many colors, 3/4" spacing, set screw locking, strain relief, polarity indicator, stackable
there are fancier versions of dual banana plugs, but none I've seen have all these advantages
I've used Nordost hollow copper and at least 2 styles of "Linn" plugs, and haven't been able to hear any huge sonic improvements over the cheapie Pomonas. AFAIC, this is the last place in the system to get spendy / trendy on audiophile bling; I'd rather invest in something special for one of my tube amps - such as (pick your current favorite/zoomy tube set )
Internal wiring ceebmoj Chip Amps 8 23rd January 2008 11:01 PM
Internal Wiring... Tomv Multi-Way 1 23rd November 2007 09:53 AM
Internal wiring Scribble Chip Amps 1 4th November 2004 06:52 AM
Internal wiring? Mayday Multi-Way 22 5th March 2004 10:54 PM
Internal wiring 2Bak Parts 5 29th July 2002 10:37 PM
Copyright 1999-2017 diyAudio
