Old 26th April 2011, 10:31 PM   #1
Default Full range with low pass high SPL sub?
Could a full range like the Mark audio 10.2 be run through a potentiometer to control output and matched with a sub of equal or lesser efficiency on a low pass filter say Hz. Could you in theory balance the output of the Mark audio 10.2 with the pot to the subs low pass output and have a complementary system? This would be in some sort of tower unit, of course the two drivers chambers would be separate.
Old 27th April 2011, 06:24 AM   #2
chris661's Avatar
In theory, yes you could.
In practice, very few people would do it that way: especially for a high-SPL application, the crossover parts required will be extremely large, and therefore expensive. Potentiometers also have low power handling compared to, say, a ceramic or aluminium clad resistor.
The alternative is to use a second amplifier to drive the woofers, and put the crossover before each amplifier, ie, create an actively crossed over system.
The parts are much cheaper than a passive (after an amplifier) crossover, regardless of if you wanted to go fully active (with op-amps and stuff) or passive line level, which involves a combination of resistors and capacitors to alter the signal going into the amplifier.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 27th April 2011, 10:50 AM   #3
norman bates's Avatar
an active crossover would make this a much easier project.
And they are fairly cheap ($100 used).
Norman
1" full range high pass newbie question troglodyte Full Range 15 26th April 2011 12:10 AM
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
High SPL full range design? JoeM Multi-Way 5 7th March 2009 08:45 PM
full range for the mids and high, bass unit for the low? swin1 Full Range 12 20th May 2006 12:48 PM
Best PASS amp for a high efficiency full-range speaker? HeadSh0T Pass Labs 37 24th December 2004 04:50 PM
Page generated in 0.07037 seconds (72.01% PHP - 27.99% MySQL) with 10 queries
