Wrapping up my Home theatre - Page 2 - diyAudio
Old 27th April 2011, 03:05 PM   #11
Well, it seems at this point, that I've resigned myself to building a third saburo. Since my end goal is to build a proper theater room once I get my own place, I would likely have ended up building a third one anyway. Having them all behind an acoustically transparent screen/wall, which I will also treat for acoustics and do it all right and proper. For the time being though, it will be on its side and angled roughly to ear level.
Now I just need to get around to ordering the driver and the wood. Anyone know places that still have the 126e? I see Dave has some unmatched 127eN, would that be close enough?
At least getting Baltic Birch is easy and cheap...
Old 27th April 2011, 04:03 PM   #12
chrisb is offline chrisb  Canada
127 would need a different (possibly much smaller) enclosure design, but even after level setting on the surround receiver would not likely exactly match the dynamics & more forward soundstage presentation of the 126
contact Dave via PM regarding single of 126
on hiatus
Old 27th April 2011, 04:15 PM   #13
Originally Posted by Ivo View Post
Perhaps the Brynn/Gabriel can be proportioned to look more like a Saburo for you by the designer?
The following would be close:
Scott's commercial redesign for FE127E BVR:
Woden Design | Venom-V
and the predecessor:
http://homepage.mac.com/tlinespeaker...map-311007.pdf
With Fostex's discontinuation of FE127E and impending release of new FF series, Scott has been concentrating on other areas.
Having built several of his enclosures over the past 5 years or so, I can attest that his designs have definitely advanced, and that the more recent plan sets are definitely worth the coin.
on hiatus
Old 28th April 2011, 02:47 AM   #14
I emailed Dave, he might have some left. Pending on that, I will likely build the saburo. Otherwise I'll probably consider the Olivia or Gabriel. I could easily make cardboard mockups to see what fits best.
Considering I lived for close to a year with my current center, anything is really an improvement and I'm not -that- picky.
As an aside, any thoughts on the sonotube subs? I saw those at Home depot the other day and realized how cheap and easy it would be to make.
Old 28th April 2011, 05:39 PM   #15
zman01 is offline zman01  Bangladesh
Ivan,
I want to hijack your thread again - or was it Douglas the last time when we started the PC and Mac discussion?
I have an uncle who's 70+ and is not happy with the sound coming out of his Samsung Series 5 (understandably so). His space is on 9" x 7.5" (wide), like a pocket opening into larger areas (I have attached my best attempt to draw the layout)... his complaint is that he finds dialogues muffled and special effects lacking - he really has to crank up the volume to uncomfortable levels in order to make the legible. I went to his place and largely agree with him, so it should not be a case of major hearing loss.
I posted a month back but with few responses - decided at that time on a baby Tysen but not sure if uncle will want to spend that much and fear that such a system would be quite overpowering in that space.
I see Chrisb active in this thread and read a lot of his observations on HT - and they make sense/sound practical to me i.e. like not having rear/surrounds (a pain with the cabling, and uncle has a really small space there).
What options do I have quick and dirty to find another excuse for another build?
I have used the BIBs for watching TV programs and the levels of detail it can bring out is awesome (Dexter opening theme has plenty...)- so have faith in FR for the dialogues and music.
-Zia
Old 28th April 2011, 05:52 PM   #16
49 - for the 19th time!!!
c2cthomas's Avatar
Hi Zia -
I'm not nearly the expert that Chris(b) or P10 are - but for such a small space - if it were me - I would be looking at the mMarS-1vo http://homepage.mac.com/tlinespeaker...map-231009.pdf
Small speaker for a small space - if you need more bass for HT add a sub.
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 28th April 2011, 06:26 PM   #17
Zia - another Dexter fan - now that caught my attention -(the moody closing theme is just as interesting in a different way - a reminder that we all have to come to terns with our own dark passenger)
FWIW, I do intend to get around to rear surrounds, but running the wires & patching will definitely take more time than building the boxes.
I'm not sure about being expert at anything but recounting my own experiences/impressions - but I'd definitely concur with c2T's suggestion of something along the size / form-factor of the little "millie" .
on hiatus
Old 28th April 2011, 06:49 PM   #18
Right, that one is cool too - melancholy and introspective... a friend told me it's called Dexter's Theme. To think of it, Dexter can be a good speaker builder also... he's good at planning things, patient, meticulous, and very good with tools!
Thanks for the pointer c2cthomas. However the only CHR-70s I have with me are Dave's ones, and I am not parting with those so quickly... so will look for a few alternatives in the meantime.
Is the Mar-Kel70 too powerful?
-Zia
Old 29th April 2011, 12:56 AM   #19
That`s very much alright. I learned what I needed to already.
I third the smaller box + small sub approach. Also, for a space that big/small I wouldn't worry about setting up any sort of surround sound. Even on my setup, just for films, I don't find that it really adds enough to the experience to make it worth it. This is largely due to the mastering of the soundtrack, can`t make noise from the back to prominent otherwise viewers get confused. Also the reason voice is only from the center (much to my annoyance). These issues are non existent for video games where the surround really makes a huge difference. But I doubt that your 70 year old uncle will do much of that.
I would also definitely try and get another pair of CHR-70, either that or the paper variant. CHP-70 on mark's website, and EL-70 on Creative Sound. Not sure how economical it is to get either to Dhaka though...
Old 29th April 2011, 06:54 AM   #20
Thanks Ivan. EL-70 will be actually easier to get for me... will have to ask one of my friends to bring from the US when they travel.
-Zia
New Home Theatre Sub dark_avenger Subwoofers 11 29th December 2007 02:28 AM
Home Theatre bhg41088 Multi-Way 4 16th August 2004 01:32 PM
Copyright 1999-2017 diyAudio
