Old 23rd April 2011, 07:37 AM   #1
norman bates's Avatar
Default w8-1808 in open baffle (pic)
baffle is 60" tall 1/2" birch ply (free) with 2 hinges from Menard's.
Driver center is 37" off the floor (center of the tv).
Center panel is 12" wide, left panel is 15" wide, and right panel is 19" tall.
Driver has maybe 6 hours on it.
I couldn't listen to it with its boosted "presence" range (harsh anyone?).
It needed -6db at 1khz and 2khz on a 10 band eq (check out its freq graph).
http://www.parts-express.com/pdf/264-894s.pdf
I added +3db @ 30hz, 60hz, and 120hz.
I figure the open baffle Feq near 180hz, then rolls off, but no baffle step is needed.
I'll soon add a foam box around the back of the driver.
And Sunday I'll move it and play with using an 80hz f-mod with a 12" or dual 15's.
Norman
Old 23rd April 2011, 11:56 PM   #2
bigdh31 is offline bigdh31  United States
The brightness will fade. Give it a 100 hours or so.
Old 25th April 2011, 12:25 PM   #3
oky doky
Zobel for Tang Band W8-1808? majerjack Full Range 9 12th September 2010 11:42 PM
Voigt Pipe for TB W8-1808 Godzilla Full Range 12 10th September 2010 05:24 PM
Tang Band W8-1808 Cabinet majerjack Full Range 30 5th September 2010 02:41 AM
Tang Band W8-1808 open baffle impressions Racket Scientist Full Range 3 23rd May 2010 03:47 PM
Tangband W8-1808 and PE Buyout Godzilla Full Range 17 23rd February 2010 04:19 AM
Page generated in 0.52818 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
