Skeeter's SuperPensil12 Build - Page 20 - diyAudio
Old 16th February 2012, 01:33 AM   #191
skeeter99's Avatar
Originally Posted by faithintruth View Post
As Plund said, nice documentation!! Didn't want to stick with natural wood grain? (Can't remember if you built with MDF).Is the front baffle thicker? Did you miter it or is it a butt joint. Excellent job on the back. I'd love to try this one after the Derwents are done. I thought I'd go with the CSS EL70's, then I read about the EnAbled drivers. I'M confused about the choice of CHR70's over the EL70's...and I've always loved paper. As many people in the FR forums have been talking about graphed performances and values but not much about the sound of their music, it's really tough to choose a good jazz/classical driver. I read a review of the "Tybone" speaker, called by Scott the Saburo and the Madison (Sachiko). Does anyone know which drivers were used in those reviews AudiogoN Reviews: Cardersound Tybone Speaker ?
Thanks! I made these out of MDF and simply did butt joints for everything. There doesn't appear to be any stress at the joints so they seem to be holding up just fine.I had never heard ANY single driver speaker before building these and since MDF is so cheap and easily milled/painted I chose to do my first build out of it. Now that I know I like the sound doing more exotic cabinets is next. I do want to do wood for my next build and want to do solid zebra wood sides with a black front baffle. Think that'd look good.
I don't listen to classical music so I can't state how these do with classical but I do listen to jazz and these are exceptional with jazz. I would highly recommend these drivers and enclosure if jazz is your music of choice. I've never heard any of the other MA drivers so I can't comment on the two you're looking at. Lots of people really like both though.
Scott
Old 16th February 2012, 01:35 AM   #192
skeeter99's Avatar
Skeeter, do you have the plans available for you alpair 12 pensils?
Scroll down the to Pensil series and they're all there: p10 hifi | Box Library / Mark Audio
Old 16th February 2012, 01:38 AM   #193
skeeter99's Avatar
Hey Scott,
Which drivers would you put in the Sachiko? Have you heard the Derwents with EL70's and/or the CHR 70's? Any comments on the sound?
Ive never heard Sachiko or the Derwints or the drivers in question so I really can't comment. What are the Derwints? I wold love to put my 12's in a double mouth horn like Sachiko though!
Old 16th February 2012, 01:50 AM   #194
Hey Skeeter, thanks for the info. I am encouraged about the 12's. Go to the Woden design LakeDistrict design series to see the Derwents (BVR). They are smaller, for the CSS EL 70's or CHR70 (Mark). Small pensils.
The zebra wood on the sides with Ebony front! Better have a really sharp router. They'd look super $$$$ and resonance would probably be low. If you made the Sachiko's with the 12's I think I'd love to drive to hear them! Probably others too.
I'm going to use baltic/Russian birch for the Derwents and then like you see how it goes for the next build. I am liking what I've read about the Fostex 126E in the Saburo and the 206E in the Sachiko's: The Spawn Family of Double Horns then read the reviews!! The owners are extatic.
Old 16th February 2012, 02:50 AM   #195
skeeter99's Avatar
Ok I found them, they weren't on Scott's site:http://www.creativesound.ca/pdf/Lake...aps-080909.pdf. They look cool.
Yeah I think the zebra wood would look cool. Pricey but all my others speakers are finely finished so they'd fit better. I dont think you can put the MA drivers in Sachiko as here designed for a totally different driver. I do want a double mouth horn though!
I'm sure your Derwents will look cool in that wood.
Scott
Old 26th February 2012, 10:17 PM   #196
bikenut is offline bikenut  Canada
Hi Scott:
Can you tell me what thickness your MDF was that you used to build your cabinets?
I see in the plans for the Super Pensils that 3/4 inch plywood is recommended.
I have a bunch of 5/8 inch MDF, but I suspect that it probably should be thicker.
Thanks, Bill
Old 26th February 2012, 11:13 PM   #197
frugal-phile(tm)
planet10's Avatar
Do keep in mind that 18mm (quality) ply has about the same stiffness as 1 1/4" MDF, so a double layer of MDF would meet that, but energy storage would be higher than the thinner ply.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th February 2012, 02:21 AM   #198
skeeter99's Avatar
Bill,
I responded to your PM but thought I would post it here as well. Definitely do use at least 3/4" if your using MDF. Panel resonances will be too high otherwise and definitely at least do the recommended holey bracing plus I'd add extra bracing up at the top as well. I used dowels cut to size and they worked well.
Scott
Old 8th October 2012, 11:07 PM   #199
skeeter99's Avatar
I know this thread is old but I wanted to just say I'm still thoroughly enjoying these speakers. They're absolutely fantastic and I couldn't be happier with them. I'm in the process of getting a new amp and preamp to work in with my current HT system as I can only have 1 system right now and am looking forward to hearing these guys with a better front end. Given how great my Gen1 drivers are I can only imagine how much better then Gen2's are
Thanks again Mark!
Scott
Old 9th October 2012, 05:24 AM   #200
zman01 is offline zman01  Bangladesh
Scott,
Good to see you at the forums again.
What amp/preamp are you getting?
I have a pair of A12P undergoing break-in, but still quite a few hours to go before crnk up time.
My first build tangmonster Subwoofers 12 10th June 2010 09:01 AM
What would you build? croat47 Subwoofers 27 22nd September 2006 04:57 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
How to build. a jleaman Digital Source 5 18th August 2003 03:06 AM
Copyright 1999-2017 diyAudio
