Using 1/2" material about 4.4 litre including vent.
If you can stretch that a bit mMar-Kel70 works pretty well.
If you are intent on keeping it to 4ish litre i'd just leave it sealed.
dave
I really like the looks of the mMar-Kel70. Its just a little wider and maybe a bit too shallow. I was thinking of propping the front up a bit to keep it more on axis and bit more depth would give it better stability as well as looking sleeker on the desk.
I would assume making the cabinet narrower and deeper would through the slot port alignment all off? Would a conventional round port work in the same volume?
I guess you could make it narrower and deeper. Issues you have to deal with are:
1/ you'd have to loose the champhers, and would be limited by the bezel size of the EL70/CHP.
2/ With the inside of the boxes closer to the driver, you will gain some chestiness/cupped sound in the midrange (our original prototypes were such and we had to widen them 10-15mm to minimize it)
3/ in the attachment i have illustrated the vent length. It is "L" shaped and you'd need to ensure the same length. I can imagine you might have to slope the back to gain sufficent breating room for the vent entrance.
4/ as long as the open part of the vent is the same, you are OK. ie take any width reduction out of the vent spacers not the vent.
No a round vent will not do the same job. The miniOnkens work because of the high ratio, high resistance vents.
dave
dave
Hi I built some speakers based around the CHR-70 gen2 that get 75Hz (-3dB) in a 4L sealed enclosure by using the capacitor equalisation trick. Hence the roll off is steeper than a conventional sealed box but the corner frequancy lower:
Make a box with 4L internal volume like this:
http://www.diyaudio.com/forums/multi-way/23208-system-pictures-description-192.html#post2524111RL]
stuffing is quite heavy with all walls having 1.5" speakear stuffing blanket glued on on them (basicly fills the box but without squashing it).
then use this series network on the driver:
http://www.diyaudio.com/forums/full-range/141496-mark-audio-chr-70-application-thread-69.html
A closed box works better I think if sitting very close to the speaker (as the port is another radiation source with very poor group delay characteristics and you are sat very close) and allows a greater stuffing density allowing the front and back walls to be closer together giving a smaller footprint.
For the sake of simplicity what about a more conventional round port vented cabinet? Re-working the mMar-Kel70 to a narrower cabinet might be kinda complicated and I wouldn't want to ruin the design.
These will at some point be paired with a sub so I can stuff the ports when that time comes but I would like to have a little more extension in the mean time. Or would I just be better off sealed using a capacitor to push the extension? If vented is a vialbe option what would be recommend for cabinet size and port?
I couldn't bear the idea of a round port. And while i was at it i made it specific to the CHP-70
dave
dave
Wow, you just drew that up now? That was quick and looks great!
That’s pretty much the exact form factor I was looking for, I think that will work really well on the desk. Though when you say specific to the CHP-70 I assume that applies to the EL70 as well since that’s my only option currently?
Also what exactly are the benefits of the slot port over a round port? I always thought they were more or less variations of the same principle.
As Dave said.
"No a round vent will not do the same job. The miniOnkens work because of the high ratio, high resistance vents."
My bad. There are currently 2 threads going on pretty much the same subject, and i got you mixed up with the Spanish guy.
For EL70 the vent spacer shrinks to 20mm, and the length of the total length of the vent goes to 164mm. Holey brace needs to be adjusted for the EL70s double magnet as well.
I can also turn on the imperial units if you prefer to work in inches (drawing is rationalized for metric thou)
A note i didn't add is that for a dngle pair of speakers it is probably not practical (unless you have a lot of scraps) to do the baffle in 15mm if the rest of the box is 12mm. i'd build up the baffle with something like cork to get the 15mm (given the thickness of the EL70 bezel a 12 mm baffle with full rebate is likely not practical.
dave
dave
Ok, no problem.
So the spacer for the vent goes from 48mm down to 20mm, the vent itself shrinks from 180mm to 164mm in length, and the brace needs to be modified but otherwise the cabinet is the same?
I'm used to English measurements but shouldn't be any problems working with metric. I can work off this drawing or did you plan on drawing one up for the EL70?
I can probably do 12mm Baltic Birch ply like you specified in the drawing and use 15mm, 18mm or 3/4 hardwood for the baffle?
Yes.
I will be doing it for the EL70 (again)
Yes. A butcherblock works better than a solid piece, but being so small it is unlikely an issue. The dimension given for the vent is the entire length to allow easy adjustment for baffle thickness.
dave
Also planet10 do you mind if I share that drawing on other forums?
It is OK to share that one.
dave
Try using the peerless/tymphany 830986, its a 3 inch fullrange, 1.5 litre sealed or 4-5 litre vented
I used a set of them in a ~.63L sealed enclosure, high-passed @ ~100Hz with a subwoofer, and was very pleased how well the Peerless worked out. Surprising playing level, very nice tonality. It was a quick & dirty PC system with anything but quick & dirty results.
- Full Range
- 4” Driver recommendations for PC setup
