High powered tweeters with a low x/o point?
Old 12th April 2011, 12:15 PM   #1
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Default High powered tweeters with a low x/o point?
Hi, my mate was asking me to help him build a half K set of back wall speakers for a studio, I'm not really wanting to go 3 way if possible but I don't think there is any such thing as a high power full range unit. What I am looking for is either a high power tweeter with a low x/o or a high power mid which doesnt need to be x/o'd at the top end (trying to avoid crossover components) another option would be to go active, and then I would not have these issues, right? but I know nothing about this. help!
Old 12th April 2011, 05:10 PM   #2
DYNABLASTERTUNERS is offline DYNABLASTERTUNERS  Serbia
DYNABLASTERTUNERS's Avatar
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
you can power it full from 1900Hz
some of my Designs www.dynablaster.deviantart.com/gallery
Old 12th April 2011, 06:09 PM   #3
kipman725 is offline kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
alternatively if you wanted a high power full range:
Alpair 10 Full Range | Markaudio
would be able to take the same power while crossed @ 300Hz with a steep crossover (1/2 energy in music is located aprox <250Hz). Fully active is always good and worthwhile.
Old 12th April 2011, 10:35 PM   #4
LineArray is offline LineArray  Germany
Maybe sensitivity will be somewhat low for that application:
https://www.madisound.com/store/manuals/NSW2-326-8A.pdf
Max. heat dissipation will be lower presumably:
http://www.tb-speaker.com/detail/1208_03/w2-748sg.htm
This one works nice as a tweeter, i already had it in a 2-way.
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 12th April 2011, 11:18 PM   #5
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Used in many pro monitors - http://www.falconacoustics.co.uk/dri...-hd13d34h.html
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 12th April 2011, 11:29 PM   #6
kevinahcc20 is offline kevinahcc20  United States
kevinahcc20's Avatar
Seas T25CF002 Millenium is pricey but can go cleanly down to 1500Hz xo with 90W long term and 200W short term power handling and 89db sensitivity.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 13th April 2011, 02:57 AM   #7
Brisso57 is offline Brisso57  Australia
Brisso57's Avatar
Originally Posted by Bill poster View Post
... or a high power mid which doesnt need to be x/o'd at the top end (trying to avoid crossover components) another option would be to go active, and then I would not have these issues, right? but I know nothing about this. help!
You could just use a (L-padded) piezo to cover the top end. That may permit using a high-power mid/tweeter.
cheers
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 16th April 2011, 02:36 PM   #8
just realised I posted this before, thanks for your help. looking at ebay and found something by dynaudio but I love the Accutons too. Decided to go DSP so I don't have to worry about passive x/o's etc
Old 16th April 2011, 03:13 PM   #9
theresa is offline theresa  United States
The 6600 ScanSpeak has a resonance frequency below 500 Hz and goes up to over 30kHz. I wouldn't get Dynaudio. I am tempted by the ScanSpeaks and if I had them would crossover at about 1500Hz which they should handle wonderfully given the miniDSPs.
Old 16th April 2011, 04:33 PM   #10
purplepeople is offline purplepeople  Canada
purplepeople's Avatar
What kind of power? What XO point? Without more clarity, I'm liable to suggest something like a 3" full-range Tangband. One of these may even be good enough by itself if the sub is crossed a little high, otherwise, you could theoretically have a system with a variable XO for different program material.
http://www.tb-speaker.com/detail/1208_03/w3-871sc.htm
:)ensen.
Those who claim to be making history are often the same ones repeating it.
High powered tweeters with a low x/o point?Hide this!Advertise here!
Low XO point / waveguide Mor den Siur Multi-Way 2 25th April 2009 09:03 AM
High bias point. jnb Tubes / Valves 4 7th June 2007 04:39 PM
Cheap low powered amp AutoAudio Chip Amps 5 16th October 2006 09:21 PM
point me to low $ midwoofer for 1st order 2 way knifeinthesink Multi-Way 4 22nd December 2005 05:51 PM
high crossover point.... plasmodium Multi-Way 3 13th December 2002 10:33 PM
Copyright ©1999-2017 diyAudio
