i want to build this speaker design:
Speakerplans.com
but i want to change the HF compression driver + horn .
Which parameters should i look?? Dispersion? Same sensibity?? Any advice please?? Wich parameters should be good with the two woofers from the speaker??
http://www.paudiothailand.com/pdf/products/PC-5038.pdf
http://www.paudio.ru/downloads/SD740N.pdf
http://www.selenium.com.br/site/assets/produtosfinal/976_pdfManual.pdf
THX for all
Speakerplans.com
THX for all
You might check over the the Pi Speakers forum / website. They deal more frequently with that type of configuration and compression drivers / horns. Good people, you may even find additional plans that you like.
Pi Speakers - unmatched quality and state-of-the-art performance
