Qts in OpenBaffle - How low can you go?
Old 10th April 2011, 08:10 AM   #41
sprinter is offline sprinter  United States
Originally Posted by Shoog View Post
If deep tight bass is what you need then a SET is unlikely to satisfy.
I have a friend who has almost nothing in his music collection with serious fast bass - because his amp speaker comb can't handle it.
I like a bit of dance music - and find output impedence critical for good listening.
Shoog
Isn't it interesting how a person's equipment (most people only have one decent system if that) can so influence what they listen to even to the extent of shaping one's genre choices. Shouldn't be surprising I suppose but it can lead to seriously limiting one's music experiences. I tend to have a very eclectic taste and to me there is only one genre: good music. I have only recently realized this phenomenon myself and why I'm so interested in trying new systems and component combinations. Unfortunately, there is simply no perfect system at any price and it is not at all unreasonable to have multiple setups for differing music styles. With my primitive temporary setup, I have already discovered that some tracks sound better on my $12 FR's (not too many though...)
What I intend to do with the SET is only use it on extended range driver from about 150 Hz up and drive the woofers with a SS amp. I've also got a Tripath to put together to see what that's all about. I'm a tinkerer. Too bad it's so expensive of a way to be...
Shrink to Patient: "Forget the Prozac, you need more Boogie!"
There are only two kinds of music. Good and Bad
Old 10th April 2011, 09:39 AM   #42
chris661 is offline chris661  United Kingdom
chris661's Avatar
Originally Posted by sprinter View Post
Interesting. I've kind of suspected that but it's always good to hear about some A/B testing done right. My intent is to biamp with a SET on the FR and a SS on the woofer. But here again, it's always subject to change. I've never heard SET so I intend to build a SimpleSE to try it out. I also just received an Arjen Helder Tripath kit which I need to put together. I've got SS. So many options, so little time.
BTW, I know that tubes inherently have high output Z, but don't the OT's take care of that assuming they have adequate capacity?
Having tried adding an output transformer to a SS guitar amp, I'd say that the output transformer probably doesn't lower the output impedance. Someone with more knowledge than I could chime in at this point to give a definite answer, but I've read about speaker impedance interacting with output transformers (Morgan Jones' project using a FE167 has an article somewhere on here), and I'd guess that all those windings would struggle to reduce the output impedance.
Chris
My work: www.grimshawaudio.com
Old 28th July 2011, 12:40 PM   #43
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Thanks for this thread guys, I've got a couple of low qts drivers that are bound for a second set of t-tqwt subs, but in the meantime, I was planning on trying out an open baffle design to see how it sounds.
I guess the good part about an open baffle is you really aren't wasting much wood if what you end up with is junk
Old 28th July 2011, 06:39 PM   #44
chris661's Avatar
Here's something that may be of use.
Variable Amplifier Impedance
Effects Of Source Impedance on Loudspeakers
Arpeggio Loudspeaker
Variable output impedance was quite popular once of a day, as this would give much more flexibility in speaker choice.
Nowadays, commercial loudspeakers tend to be designed to be driven by a voltage source, so impedance varies wildly through the pass-band (3rd link).
Chris
Old 23rd May 2017, 09:43 PM   #45
JungDA is offline JungDA  United States
Here's what Linkwitz says:
Frequently Asked Questions
Old 25th May 2017, 04:19 PM   #46
I also found the chart on this page to be very helpful in visualizing how the qts affects response: https://translate.google.com/transla...html&sandbox=1
Old 25th May 2017, 08:57 PM   #47
Scott L is offline Scott L  United States
There doesn't seem to be much middle ground. Most folks either love, or hate, the sound quality.
Old 26th May 2017, 03:14 PM   #48
I am researching OB speakers because I am thinking about building some. I haven't listened to any, so what aspect do people dislike about them?
Old 26th May 2017, 03:23 PM   #49
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Hi, well you've discovered Linkwitz Labs site so you're on the right track. If we forget the need for space and the work necessary for good bass, then I reckon what some may dislike about them is the more defuse soundfield....personally I prefer it, so it's a matter of taste. Some will say you can't get good deep bass from OB, but they are wrong . What you won't get is the thump in the chest pressurization if that's what you're after
Subwoofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 26th May 2017, 03:53 PM   #50
You would have to listen, and decide for yourself. Everyone has different tastes and their own built-in and imprinted sense of what "real" sounds like.
Qts in OpenBaffle - How low can you go?Hide this!Advertise here!
Possible use of a very low QTS driver? giralfino Multi-Way 7 10th January 2011 04:12 PM
what sounds best . . . Low Qts in small cab or higher Qts in bigger cab mikelm Subwoofers 18 15th July 2009 10:46 AM
Long voicecoil, low Qts drivers TwangBar Multi-Way 0 12th October 2006 12:47 AM
Need 8" sub - low Qts, low Fs??? geolemon Subwoofers 14 19th June 2005 12:38 AM
Low Qts woofer bigwill Subwoofers 19 15th March 2005 07:45 PM
Copyright ©1999-2017 diyAudio
