How much will a TL lower a drivers F3 by?
Old 5th April 2011, 04:42 PM   #1
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Default How much will a TL lower a drivers F3 by?
Roughly... I know it depends etc etc
comparing a driver in an optimum sized BR cabinet reaching an F3 of say, 55 hz, roughly what would the same driver get to using a TL?
Old 5th April 2011, 05:05 PM   #2
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
A general rule of thumb, for what that's worth, is that you should not tune a TL lower than 0.707xFs.
Bob
Old 5th April 2011, 05:22 PM   #3
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Theoretically you can tune the box to the lowest freq ,but this lends to have a big air column moved by the membrane ...the lowest the freq , the longer the column . So the cone is loaded at the lowest frequencies because the mass of air ,which is a fluid , can vibrate together with it ,and raising the frequency it looses the spring effect . So ,depending primarily on the driver's
characteristics ( Qms )and the geometry (folds) of the labirinth and the acoustic resistance (stuffing),the mass of air contained inside effectively lowers driver's resonance freq , but .... air is rather a lazy fluid ,and after a transient reproduced by the woofer ,before the fundamental exits the terminus
, time passes ...and often there's no perfect design that can overcome this issue .
Old 5th April 2011, 07:45 PM   #4
but you can get better bass extension with a TL for a given drive unit ?
Old 5th April 2011, 07:59 PM   #5
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
It all depends on the unit. A TL is not a fix-all. Some drivers work well, some don't.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th April 2011, 08:11 PM   #6
Me ?
I haven't 'played' with TL as seen on early '70 (60 ? ) designs. I prefer it tapered and with the driver not placed near the closed end ,i.e.no surfaces in the vicinity of the cone ...You know how DIY enthusiasts take their approach to the project ,they want to do everything perfect ...despite the final judgement may be compromised by some self-ego...
Surely the bass is there ,I just don't know if at some listening levels (which may be even not too loud ) the de-correlation of emission from the woofer and the terminus makes happen some alterations like phase issues -ripple or whatever .
Old 6th April 2011, 02:12 PM   #7
dave
I can't remember if the QTS shd be above or below .4 to work well.
How much will a TL lower a drivers F3 by?Hide this!Advertise here!
Fb Hz lower than F3????? Richard Ellis Multi-Way 22 4th May 2010 06:56 PM
19 Hz TL ingvar ahlberg Multi-Way 16 7th February 2007 10:15 PM
Best Drivers for 40 - 170 Hz Sealed Box ? Oz_Audio Multi-Way 11 1st February 2007 06:36 PM
How to calculate volume, F3 for 2 drivers? ezkcdude Subwoofers 2 26th January 2006 07:41 PM
MTM’s or TMM’s: using sealed upper and TL (or similar) lower drivers? Andy G Multi-Way 3 18th November 2002 04:46 AM
