Programs that Down/Up - Scale box dimensions
Old 4th April 2011, 12:28 PM   #1
Puffin is offline Puffin  United Kingdom
Default Programs that Down/Up - Scale box dimensions
Does anyone know of any free programs to convert plans to accommodate a smaller or larger enclosure?
Old 4th April 2011, 04:36 PM   #2
chrisb is offline chrisb
Even if such simple CAD conversion programs exist, I doubt few designs are as simply scalar as that - several other variables in system tuning would need revisiting.
like my mind, this space intentionally blank
Old 4th April 2011, 07:16 PM   #3
Hi Chris. I am just using up spare time by putting a full ranger in an existing cabinet. The cabinet is slightly larger than the plans for the dedicated driver. If it works - great, if not....nothing lost. It is the internal partitions that I wanted to scale-up.
Rob.
Old 4th April 2011, 07:26 PM   #4
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
What you want is a speaker modeler. You plug in the box volume and driver details an dsee if you can come up with something that works. Do not ignore the option that "bricks" can make the internal volume smaller.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th April 2011, 09:32 PM   #5
purplepeople is offline purplepeople  Canada
purplepeople's Avatar
Sounds like you need a parametric 3D modeler and those are never free.
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 5th April 2011, 02:32 AM   #6
Brisso57 is offline Brisso57  Australia
Brisso57's Avatar
Rob.
If all you have is a sealed cabinet that's oversize for the driver then just add solid fill to lower the internal volume. Either that, or fit an internal blanking plate to achieve the same thing. Be sure to make it airtight.
You may have to experiment with the amount of fill.
If the cabinet is vented, then you'll need to also do the calc's to find the diameter/length of the vent. Not too difficult if you have the driver data. If you don't have or can't get the driver data, then your other option is to identify another design using that driver and start with the diameter and length of vent in that cabinet.
cheers
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 5th April 2011, 06:42 PM   #7
Thanks for the replies.
Programs that Down/Up - Scale box dimensionsHide this!Advertise here!
Sealed box dimensions influence IG81 Full Range 6 7th April 2009 08:08 PM
Box dimensions hewlew1 Subwoofers 1 6th November 2007 11:07 PM
Designing a box based on room dimensions StevenLB Subwoofers 1 14th December 2005 08:56 AM
Help calculating box dimensions & port jim_vt Full Range 6 5th April 2005 04:08 AM
Box dimensions Vivek Multi-Way 10 16th September 2001 08:02 PM
