Book shelf speakers for SE tube.
Old 15th April 2011, 11:23 PM   #31
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
We tend to use strands of 24g solid core out of cat5 cable. Cryo treated with the Teflon jacket
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th April 2011, 08:37 AM   #32
M Gregg is offline M Gregg  England
dave
Dave,
Thank's for your help.
Do you strip the insulation and then use the strands as a single flexible cable? Cover with either PTFE or Teflon.
I guess liquid nitrogen drop the cat5 strands in as a flex let it boil off. Then fit the jacket. How many strands or is it a trade secret?
I surprised you don't use PTFE silver coated copper flex? I guess you have tried other things? I am curious how you came to this conclusion!
M. Gregg
Old 16th April 2011, 07:25 PM   #33
Just a quick question,
I just noticed that the mounting screws for the Alpair 7 are just turned a small amount off center is this correct?
M. Gregg
Old 17th April 2011, 03:43 PM   #34
Dave,
Its a shame that the Alpair 7 does not come with the paint job you do.
LOL feels like there is something missing when you look at them.
I will try the cat5 I think the silver plated cable may be to bright. I will just go and get some Liquid Nitrogen from the tank in the garage "Not" ..LOL
I will strengthen the joints with silicone adhesive " Fish tank glue" should be interesting might help stop some resonance.
Just going to try cutting the mounting hole for the Alpair7..Not the easiest thing with the large step.
Any thoughts on connectors for the Alpair and "binding posts"?
Just trying to get the sound as intended with your design!
M. Gregg
Old 17th April 2011, 07:53 PM   #35
frugal-phile(tm)
planet10's Avatar
We strip the outer insulation and then separate the pairs. Typically we then just use one of those pairs inside (same colour in each box). For speaker cables, you can take it further, separating the 2 wires in the twisted pair and then either running the 2 strands roughly in parallel on a flat substrate (i used packing tape), or spiral it around something circular (Chris used plastic aquarium pipe, i have some (unused) cotton rope, foamed teflon would be really good).
You never drop stuff into LN, you pour the LN onto the object. I haven't done it myself. The 1st batch was done by one of the most experienced guys, the 2nd batch by an engineer/member at BC Hydro so that we could give away chunks at VI diyFEST. I don't know how much it helps, but it can't hurt.
Speaker wire choice is a can of worms. What is "best" is very sysyem dependent, and out amoung the candidates there is huge amount of snakeoil out amoung the solid products,
So being frugal-philes(s), and believers in thin & solid core, we stick our heads in the sand, and just use the CAT5 strands, consistent, pure, decent sounding, & dirt cheap.
All our designs are intended to be made (have to be made) so that the speaker wire can be attached to the posts outside of the box (ie posts on a removable cup/plate), so that speaker wire can be changed.
Binding posts. We have found that all too often the blingier posts don't work as well as the cheap ones, We use a cheap, small round cup with cheesy looking plastic posts (but not metal). Small circular installation hole (50mm/ less panel weakening, but a little awkward to fingers tighten), minimal metal. We can swap out the posts to upgrade. (Eichmans are a tight fit)
dave
Old 17th April 2011, 07:55 PM   #36
frugal-phile(tm)
planet10's Avatar
I have not noticed it, but i would not be surprised, A6.1 and A5 had mounting holes offset from the basket legs.
dave
Old 17th April 2011, 08:00 PM   #37
frugal-phile(tm)
planet10's Avatar
There are available... and the brave (with experience) can diy the spots.
I've been living with spotted drivers so long any without seem naked. But most important to me, about the A7eN, is the increase in DDR that expresses itself foremost as a 3D image that is quite abit deeper than the stock ones.
dave
Old 17th April 2011, 08:30 PM   #38
Dave,
What can I say!
Thank you so much for the help.
From what I am told I think that the freeze and warm up with the Liquid Nitrogen has the effect of de-stressing the cable. A bit like how copper work hardens -but in reverse. This seems to effect the sound making it "Less harsh".
M. Gregg
Old 17th April 2011, 08:34 PM   #39
digits is offline digits
digits's Avatar
Imagine how neat those blocks would look if applied with a modified CNC plotter of some sort... now thats a DIY project.
Old 18th April 2011, 01:09 AM   #40
Bigun is offline Bigun  Canada
Bigun's Avatar
wow, Dave, I gotta say those cones look good with the polka treatment !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Book shelf speakers for SE tube.Hide this!Advertise here!
felt speaker cloth? hidden speakers on rear shelf bdimag Car Audio 5 2nd June 2010 09:23 PM
Small book Shelf Project ANTHONY2181 Multi-Way 2 13th July 2007 06:31 AM
tube id book sunseeker Tubes / Valves 1 28th August 2005 02:20 PM
shelf speakers wanted kmj Multi-Way 1 25th September 2004 06:29 AM
help me to improve my book shelf speakers renjiish Multi-Way 3 20th August 2002 02:50 PM
