Book shelf speakers for SE tube.
Old 5th April 2011, 06:02 PM   #21
M Gregg is offline M Gregg  England
I know that porting will effect position of the speaker,
However what method do you think is most efficient to transfer bass to the listener?
Not using a sub!
It's interesting you mention mass loading some time ago I had some Tannoy speakers, these could have sand put in the bottom to mass load. So thinking this would be better I filled the bottom with sand. All the bass seemed to disappear! So the sand came out!
Will Mark Audio ship Alpair7 to the UK?
M. Gregg
Old 5th April 2011, 06:19 PM   #22
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
If you sand fill a speaker, it is done in a unused cabity of the lougspeaker. This aids stability by lowering the centre of mass. If you put sand into the speaker volume, you will decrease bass because you are reducing the cabinet volume (and if ported screw up the tuning.
In UK, you get A7 from Blue Planet (they recently cleaned Mark out (ie he has none) or if they have any left Alium Audio) Matched & modified from that planet10 guy (as in the picture attached earlier).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th April 2011, 06:53 PM   #23
dave
This was in a cavity in the base designed for loading "closed partition". Perhaps it was just tighter, however it seemed less.
Thank's for the links!
M. Gregg
Old 5th April 2011, 07:59 PM   #24
Sorry back again,
What are your thoughts on covering the inside or back panel with sorbothane sheet?
M. Gregg
Old 5th April 2011, 08:15 PM   #25
frugal-phile(tm)
planet10's Avatar
To what end? It is not as good at damping as the specified wool felt, and adds mass to the panel without adding stiffness.
Now putting a layer of sorbathane (or some sort of feet) between the "stand" and the bottom of the speaker may have benefit.
dave
Old 6th April 2011, 10:57 PM   #26
wagtail is offline wagtail  Ireland
wagtail's Avatar
alpair 7's stocked here Europe Audio - Home page got mine from them good service reasonable delivery charges,
simon
Old 7th April 2011, 08:07 AM   #27
simon
Thank's for the link.
M. Gregg
Old 12th April 2011, 06:32 PM   #28
Just for info,
I have ordered the Alpair 7's in gold.
Should be interesting!
I'll take a look at the box build!
M. Gregg
Old 12th April 2011, 06:42 PM   #29
frugal-phile(tm)
planet10's Avatar
Originally Posted by M Gregg View Post
Alpair 7's in gold.
It is called gold, but it is really copper....
A6.1 in gold
A7 in gold/copper
All the colours have their appeal
And it matters little with your eyes closed and your foot a-tappin'
dave
Old 15th April 2011, 10:52 PM   #30
Just for info!
I received the Alpair 7's today.
I decided to use 18mm Birch ply for the box, 15mm is quoted.
The volume of the box remains the same as quoted in the plans!
I have cut the ply to size and used wood strip to cover the ends.
Let you know how it goes!
Any thoughts on speaker cable used inside the box.
M. Gregg
Book shelf speakers for SE tube.Hide this!Advertise here!
felt speaker cloth? hidden speakers on rear shelf bdimag Car Audio 5 2nd June 2010 09:23 PM
Small book Shelf Project ANTHONY2181 Multi-Way 2 13th July 2007 06:31 AM
tube id book sunseeker Tubes / Valves 1 28th August 2005 02:20 PM
shelf speakers wanted kmj Multi-Way 1 25th September 2004 06:29 AM
help me to improve my book shelf speakers renjiish Multi-Way 3 20th August 2002 02:50 PM
