I just destroyed a pair of FE166En's - Page 3 - diyAudio
Old 3rd April 2011, 03:56 PM   #21
Godzilla's Avatar
>>> Yes, any hint of sibilance is gone, but at what price.
Strangely enough, i find nowadays a hint of sibilance no longer bothers me. Too much and it does. If i had the choice i would rather do without it but NOT at the expense of the overall sound.
I looked at the charts again and am surprised at the difference the tweaks make. The upper frequencies are certainly different! I did not expect them to be as ragged as the original 'virgin' driver.
I don't modify expensive drivers. I guess we all have to make a decision as to what is expensive to us since we all have different budgets. The Fostex 166 is something i'd choose to leave 'as is' or perhaps try the removable 98 cent tweak. I feel bad about what happened.
Thanks Leon for posting your subjective listening results.
Old 3rd April 2011, 04:24 PM   #22
Thank's Zilla for the correct term : "98 cents tweak".
Couldn't find it in my memeory at the time of posting.
2 out of 4 people now do use a FT17H ( 1,8oHm , 2,2~1 uF) in combination with the FE166En
The other 2 only use some foam : around 3 pieces 1cmx 1cm and a sligtly oversized square piece inside the whizzer. This is special open foam ; you can breath throuh it!!
Leon
Old 3rd April 2011, 06:55 PM   #23
larryldspkr's Avatar
I tried several different "doping" schemes on drivers in the mid-seventies, adding mass just seemed to roll off the top end! Makes sense really, glad I got that out of my system! Now I just listen to speakers the way the "factory" intends.
Cheers
Old 3rd April 2011, 06:59 PM   #24
BudP is offline BudP  United States
BudP's Avatar
Hi Bob
I think I have done my last Enable and mod podge treatment.
I just did a pair of 126en and don't like the results,
just way to bright sounding you hear all the details
but just to much, I guess I lean toward a warmer sound,
enable is just way to in your face sounding to me.
Can't speak to the modge podge portion, I have never attempted to treat speakers with that material, though I have used straight PVA on literally hundreds of drivers, working for Nestorovic Labs.
I have to agree with the way too bright and in your face comment about the 126, but my opinion covers treated and untreated 126's. I really do not understand why Fostex deleted the 127 and left the 126. I have a pair of 127's, with the full Dave treatment, and three extra ring sets that come from the "tap test" advancement. The drivers are incredibly smooth, lively and colorful, with not a single shriek from any of Jessica Williams piano notes and her playing will find them. I have attached the modified 126 / 127 pattern guide, you really should use it on those 126's. They will still be bright and in your face, but at least it should kill the painful ear zings. I have treated a few pairs of 126's and I really did not like them, at all.
Bob, is there some way I can get involved with this 166 problem? Maybe you can send the drivers here and allow me to fiddle about with them?
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 3rd April 2011, 10:21 PM   #25
Bob Brines's Avatar
Bud
I suppose I could send them to you. They are of no value to me.
I don't think that doping the main cone is the problem. The disaster occurs around and above the frequency I would expect the dome and whizzer take over. It would require sacrificing several drivers to confirm, but I suspect that this is one driver that you don't want to dope the whizzer and you done want to remove the dome/dust cap. The dust cap is horn loaded by the whizzer. Other than the ringing around 12k, there is no HF output on my modified driver.
Bob
Old 3rd April 2011, 10:53 PM   #26
BudP's Avatar
Perhaps you should send them to me. I have been worrying at this whizzer cone issue for a while now and the last three pairs done were musically very useful. I would be happy to treat a pair of new ones for you too if you like.
The real issue with them appears to be some form of Raleigh wave at both ends of the small cone. I am used to finding and treating these on cones larger than 5 inches actual outside diameter. The same process used there also works on the whizzer. I will provide you with whatever I can discover and an untreated pair will show where you can get to. I will be happy to purchase the untreated pair should I not understand what they need and mess them up.
Do please PM me and I will provide an email so we can plan.
Bud
Old 3rd April 2011, 11:26 PM   #27
Bud
I actually put all those ring sets on the 126en,
you had already sent the pdf files to me a few weeks back,I don't know what is going on
with these drivers,maybe I need to go with
a warming sounding driver all together.
I had the old 126e I did 2 coats of mod podge
and the tri foil pattern and used them for
maybe 3 or 4 years they seemed to be much smoother not in your face,actually they sounded
amazing in the set of Saburo's I built.
wishing I still had those.
Bud
Old 3rd April 2011, 11:48 PM   #28
frugal-phile(tm)
planet10's Avatar
Scott,
Please post a picture of your application, it will give people some important context to your results.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd April 2011, 11:59 PM   #29
Here you go Dave.
hammer away.
Old 4th April 2011, 12:07 AM   #30
frugal-phile(tm)
planet10's Avatar
Thanx Scott. By way of comparison:
I will leave it to Bud to comment.
dave
New FE166En's Bob Brines Full Range 44 4th October 2010 07:21 PM
Are my two TDA1562 destroyed?? newbadboy Chip Amps 2 10th June 2009 01:13 PM
Drivers and FETs destroyed, Help Please smitten Class D 1 9th June 2007 07:33 PM
SG3525 destroyed MOSFETs SMPS3525 Power Supplies 16 21st September 2006 01:38 AM
Is SAA7378GP destroyed? Gasho Digital Source 5 8th August 2005 05:10 PM
Copyright 1999-2017 diyAudio
