I just destroyed a pair of FE166En's - Page 2 - diyAudio
Old 3rd April 2011, 03:03 AM   #11
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Bob Brines View Post
brickwalls at 5k and doesn't recover to the unmodded traces until 9k.
Bob
Killing the presence range and most of treble...
Old 3rd April 2011, 03:27 AM   #12
Bob Brines's Avatar
Originally Posted by planet10 View Post
Bob,
Need to know more details about your application. It is well known that too heavy a hand can screw up the HF.
dave
I put two coats of Mod Podge, diluted 1:1 with water. Cone and whzzer got the same treatment. Note that problems don't occur until 5K. Also note that the notch is much deeper with the phase plugs. I did a test with the phase plug removed, i.e. without the dustcap. The trace was very similar to the one with the phase plug in place. I know from previous experience that the real effect of a phase plug is to put a notch in the frequency response that corresponds to the sibilance spike of female speakers who swallow the mic. Makes the singers sound smoother. I'm going to check my other speakers with phase plugs. The effect may be primarily due to removing the dust cap.
Bob
Old 3rd April 2011, 03:43 AM   #13
Godzilla's Avatar
I just modded a Beta 12lta with great results! Removing the dustcap improved the driver and adding the phase plug smoothed the sound nicely... most notably with female vocals. Sorry about your drivers Bob... that stinks! Thanks for posting your charts.
Zilla
Vive la musique!
My blog: https://speakerprojects.wordpress.com
Old 3rd April 2011, 03:57 AM   #14
frugal-phile(tm)
planet10's Avatar
1:1 is a higher dilution than i use, much higher... Just a couple weeks ago i destroyed a pair of FE167e experimenting with that wet a solution -- it warped the cones
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd April 2011, 04:03 AM   #15
Salas's Avatar
I know from previous experience that the real effect of a phase plug is to put a notch in the frequency response that corresponds to the sibilance spike of female speakers who swallow the mic. Makes the singers sound smoother. Bob
Sibilance is centred around 7K.
Old 3rd April 2011, 05:45 AM   #16
Bigun is offline Bigun  Canada
Bigun's Avatar
7k being the cone break up mode for the now defunct 127e. I tried the damar / trifoil treatment on a pair of those cones but it didn't really fix the problem. It made a slight improvement but I think I 'lost' a little magic in proportion. Based on my experience with the 127e I'm not so convinced that Fostex always knows what they are doing with their designs. However, I would balance my experience against that of many happy customers of the 127e.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 3rd April 2011, 10:16 AM   #17
To Bob Brines,
Working on the new fostex as well.
Adjusted my previous blh design for the FE166En.
Did a group build with four people.
Compared the "old"166 to the "new.
New : after break-in 200+ hours the still had some "metal" sound in them.
So we started some reversible tweaks.
long story short:
open cell schuin.JPG in combination with the FT17H.
See pics.
Leon
Old 3rd April 2011, 10:17 AM   #18
Forgot one.
Leon
Old 3rd April 2011, 10:50 AM   #19
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Hi Bob,
As you've already "ruined" your driver, I guess it's worthwhile to remove the whizzer as well and see if the high frequency resonance is still there. Just my two cents though.
Old 3rd April 2011, 12:57 PM   #20
Originally Posted by bigaudioscotto View Post
Hi Bob
I think I have done my last Enable and mod podge treatment.
I just did a pair of 126en and don't like the results,
just way to bright sounding you hear all the details
but just to much, I guess I lean toward a warmer sound,
enable is just way to in your face sounding to me.
It's always frustrating when a mod doesn't work in the actual listening. I have done a few Enabl jobs over the past three years and followed much of Ed's (Ed Fontaine) discussion.
As Bob said, and if you allow for some variance in application technique, I've found the result to take the "life" out of speaks as well. The same cannot be said for phase plugs. Phase plugs can make a silk purse out of a Pioneer 4 in. NSB.
New FE166En's Bob Brines Full Range 44 4th October 2010 07:21 PM
Are my two TDA1562 destroyed?? newbadboy Chip Amps 2 10th June 2009 01:13 PM
Drivers and FETs destroyed, Help Please smitten Class D 1 9th June 2007 07:33 PM
SG3525 destroyed MOSFETs SMPS3525 Power Supplies 16 21st September 2006 01:38 AM
Is SAA7378GP destroyed? Gasho Digital Source 5 8th August 2005 05:10 PM
Copyright 1999-2017 diyAudio
