Taming the High Frequency of Tangband's Titanium W4
Old 30th March 2011, 02:42 PM   #21
IG81 is offline IG81  Canada
IG81's Avatar
IMHO, best thing is to start simple, no correction circuit or EQ. That's what I do with new speakers. After a while, could be a few songs or a few days, I get a better feel of what I like or don't like about the speaker system and act accordingly.
Hope the driver and cabinet works out well for you. Let us know how it turns out.
IG
Old 1st April 2011, 04:58 AM   #22
j.michael droke is offline j.michael droke  United States
Hi there: My approach to a two way speaker set-up is to biamp a TB 4-inch bamboo cone driver with a bass unit. The TB's slightly forward sound can be tammed by adjusting the tone control. The TB is set in an open back with 60 degree wings. I tried it in various experimental boxes, however I prefer it in the OB. The biamp crossover is set at 135HZ to the TB. I like the set-up enough that I'm constructing OB for TB 5-inch. I listen to classical and 50/60's coljazz music. ...regards, Michael
Old 1st April 2011, 07:44 AM   #23
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Hi Michael,
I am trying to have a compact full range system instead of an elaborated open baffle two way system. I am sure it sounds wonderful in open baffle, sure it will. I know the tone control can help, but I would like to bypass tone controls on receiver/integrated amps as I found that they can add some "cloudiness" to the sound. Direct output sounds a lot better IMHO.
Old 1st April 2011, 03:51 PM   #24
activexp is offline activexp  United Kingdom
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Hi borispm, you might like to take a look at the frequency response leveller (notch filter) calculator here:
Strassacker: Lautsprecher - Boxen - Selbstbau
I found it very useful for flattening a 6dB peak at 8.5K on the TB W4-657D.
With the calculator you have to enter the impedance of the speaker at the frequency to be suppressed.
Steve
Old 1st April 2011, 04:29 PM   #25
borispm's Avatar
Thanks a lot, Steve! It seems like I will end up with an .15mH inductor, an 8ohm resistor and an 1.66uF cap.
Still very hard to choose between a single inductor or the notch filter. Everyone says I should make it as simple as possible i.e. no filter at all, but the rising frequency response and broad and tall peak at 10kHz-15kHz looks terrible to me and I can already imagine what a 10dB peak in that region be like...
Old 1st April 2011, 06:39 PM   #26
AstroSonic is offline AstroSonic  United States
Borispm,
"Seems like everyone advices me to not to use correction circuits of any kind, maybe I should compromise between filterless, lively sound and filtered, polite sound by using a single inductor instead of a more elaborated circuit. After all it's better to have lively sound than dull and lifeless sound. 0.2mH seems like a decent start, thanks for your suggestion, IG."
I also suggest not using a correction circuit (at least high level). Very often peaks in the frequency range and magnitude you are concerned with are prominent on-axis (where measurements are usually made), but are not present 10-20 degrees off-axis. Therefore, the only compensation you will need is a little toe in - have the speakers cross in front of you instead of aimed straight at you. Provided that there is not a highly (acoustically) reflective surface behind you or directly to your sides (like glass windows or glass doored cabinets) a little toe in will largely resolve the HF peaking in this driver.
My experience with series, high level correction ciruits is similar to that reported by GM. They seem to take some 'life' from the sound.
OTOH, Correction networks can be used to advantage with drivers for which toe in does not work satisfactorily and that have otherwise exceptional performance. Lastly, there is also a personal preference/tolerance issue here. They are also useful for people who can't tolerate the residual peaking audible off-axis, but otherwise like the sound of the driver.
My preference is to select drivers that won't need correction circuitry.
Bob
Old 1st April 2011, 07:34 PM   #27
IG81's Avatar
Can't speak for the others, but what I am saying is to at least START simple, with no correction circuit. Nothing wrong with using them afterwards if that's what it takes to make them sound better to you. One cannot judge from a FR graph exaclty how a speaker system will sound.
Actual example : I have some Philips AD9710, which have a notorious peak around 3kHz, but I find that, with a lot of source material, there is no need to do anything about it. Although on some stuff, I will notch it down a bit with my preamp's parametric tone control.
I just don't want you to turn this into a headache before actually knowing if the peak will cause you one.
IG
Old 2nd April 2011, 04:26 AM   #28
borispm's Avatar
Seems like the best approach is to have the external circuits then... So that I can switch between filters.
Old 2nd April 2011, 06:25 AM   #29
deskel is offline deskel  Turkey
nice
Old 3rd April 2011, 06:39 PM   #30
rx7mark is offline rx7mark  United States
FYI, Check out what other designers have done with this driver.
The 3CRTi
Parts Express DIY Project
and the Lineup series, with and without tweater
HTGuide Forum - Lineup Series Build Thread (F4, D4, D44, R4, R44)
From a little research the filter on Wolf's 3CRTi works the best and has been used on a couple of other DIY efforts to good effect.
Good luck
Mark
Taming the High Frequency of Tangband's Titanium W4Hide this!Advertise here!
FS: Pair, Tang Band W4-1337SD 4" Titanium Cone Drivers, NIB matevana Swap Meet 7 12th December 2010 02:41 PM
taming the rising high freq response of FR drivers pforeman Full Range 11 12th May 2009 12:45 PM
Taming rising frequency response 'naturally'... Taperwood Full Range 31 12th May 2006 02:50 AM
