Hello all!
Since reading that open baffle sounds nice and has a better radiating pattern I've thought of merging the Carlsson inspired pop box with the open baffle concept: It would be used primarily for music listening on low volume, no earthquake capable sound needed ![]() Dipole/Ripole subwoofers to handle up to somewhere 100 - 300, or as high as they can handle while still performing optimally. Then do an open baffle with upmounted full range driver surrounded by four inwards mounted tweeters to help from about ~ 4-5 khz and upwards, for if I'm not mistaken the FR driver would in these higher frequencies have inadequate dispersion. ![]() The baffle would stand on for example on legs and stand 50-70 cm high. The idea is to create an open baffle speaker without a soft spot inside the room, I move around in the room and want to enjoy the sound everywhere. MiniDSPs would be used to handle sub -> OB speaker crossover and EQing while the FR and Tweets would be passively crossed, maybe active there too in the future though. Do you think this could work or is there a better existing solution that would also give me softspot-less sound? Since open baffle supposedly already have a good spread would it still be advantageous to flip it horizontally or is it better to have the baffle vertical as normally done? And if it would work, approximately how large would the baffle have to be? Would it have to be gigantic or can one get away with something in the line of 25 x 45 cm? // Olle EDIT: This might be better placed in "Multi way", so if it should and some mod sees it maybe they can move it? =) Last edited by OllBoll; 27th March 2011 at 07:04 PM. Reason: I think this should go into Multi way instead |
#2 |
Of the few omni-directional speakers I've heard they sounded best placed at a central location, as opposed to the more traditional stereo arrangement.....is this the plan? Of the few OB speakers I've heard, I did always enjoy the dipole effect they have on soundstage......they have a sense of space I've not heard on a boxed speaker. With that said, I don't see a point in going OB here, as you'll just be sending all the reflective energy into the floor. I doubt any fullranger is going to have the dispersion to listen at any distance, so IMO you'll exacerbate the "dead spot" issue ten fold (instead of having a room response gap, you'll have a massive gap in the speakers response. Additionally, dependent on the moving mass and suspension compliance of the driver, you could run into sag issues. I could be way off...try it and report back.
It is only rarely that one can see in a little boy the promise of a man, but one can almost always see in a little girl the threat of a woman. ~Alexandre Dumas |
#3 |
Both yes an no, the ideal is to have a fairly traditional stereo arrangement BUT where I'm not limited to a central soft spot of listening but instead can move around the room.
Sure, I will sometimes hear the left channel with higher volume than the right but thats okay, but I want to hear all frequencies of each channel with equal loudness wherever I am. In other words, I don't want to loose treble if I move out of some soft spot =) I've also thought of using traditional BR clones of that original speaker but with a Dipole sub crossed right below you can hear directionality, or stereo Dipole subs with smaller BR speakers ontop of them. But the idea here is to remove all noise from having an enclosure that supposedly Open Baffle should solve, right now I have BR clones of that speaker which works really well, no soft spot at all which is why i thought about improving it more. So an idea, as it is now the reflections are directed to the floor yes but what if you placed a cone underneath? ![]() Wouldn't down reflections then be directed around it? Last edited by OllBoll; 27th March 2011 at 08:05 PM. |
#4 |
some practical considerations - this thing will collect dust and any other articles that come near it - if you have kids, forget it!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| For Full Range With Subs -- Sealed Box Vs Open Baffle ? | DrDeville | Full Range | 4 | 21st January 2007 05:26 PM |
| Modelling a semi-open-baffle in WinISD for use with a sealed-box woofer? | Spasticteapot | Multi-Way | 2 | 27th November 2006 09:49 PM |
| Time-Aligned Open Baffle Line Arrays.... | chops | Multi-Way | 36 | 25th January 2006 12:15 PM |
| Open Baffle vs Box Speaker Question | Robert McLean | Full Range | 23 | 24th May 2005 09:54 PM |
| Australians- what solid timbers for baffle? (open baffle loudspeaker) | tktran | Multi-Way | 13 | 29th November 2004 11:09 PM |
| Page generated in 0.09307 seconds (74.75% PHP - 25.25% MySQL) with 11 queries |
