Need some direction/advice for upcoming build - Page 3 - diyAudio
Old 29th March 2011, 09:14 AM   #21
frugal-phile(tm)
planet10's Avatar
It is unlikely this will be your last FR build
Start cheap and work your way up.
Yes, A7 is better than EL70, but it will show every wart on your choosen amplifier.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th March 2011, 09:42 AM   #22
zman01 is offline zman01  Bangladesh
dave
Dave,
I guess you speak from expereince? At least,I am hooked .... one build completed, one going on, bought drivers for the next 2 but we're never gonna survive unless we get a little crazy... right?
Old 29th March 2011, 09:53 AM   #23
Thanks Dave, I think I'll just go with the EL70, I don't think the difference is going to be really worth it until I start focussing on my source which is a little bit down the line.
Attached is the revised plan.
I've tweaked the sizes a bit for easier cutting. It has resulted in a bigger box but I've kept the ratio to 1.4, so I reckon it will work!
Is chipboard a huge compromise over plyboard for this design? It's about 1/4 of the price!
Old 1st April 2011, 11:13 AM   #24
Well, EL70 drivers ordered. I'll be going for the design that I posted just above and I'm really looking forward to it!
Old 1st April 2011, 11:29 AM   #25
frugal-phile(tm)
planet10's Avatar
Looking forward to further updates as you get along
dave
Old 5th April 2011, 02:44 AM   #26
Quick question - with the inverted BiB, how far off the ground should the box be, or is it again a matter of finding what sounds best? I am thinking about experimenting by putting blocks of wood under the corners first, but if there is a recommended amount then I will just make the sides longer and have a front and back vent..
Old 5th April 2011, 03:34 AM   #27
frugal-phile(tm)
planet10's Avatar
Originally Posted by Commited View Post
...or is it again a matter of finding what sounds best?
Yes. Quite a bit of tuning latitude there.
dave
Old 5th April 2011, 05:57 AM   #28
Ok, I'll build it as designed and then use blocks of wood on the floor to raise or lower it to find out how high the spikes need to be!
Old 5th April 2011, 07:19 AM   #29
Going to pick up some cut 15mm CD plywood in the morning! Looking forward to picking it up and getting started.
Old 13th April 2011, 01:04 AM   #30
The weather today was about as miserable and wet as any I've seen in the UK or Ireland. That made it the perfect day for working inside on some speakers!
Unfortunately, tools are sparse but I managed to get my hands on a VERY wonky jigsaw and 2 half broken clamps. Oh yes, this was already shaping up to be a successful build...
Anyway, with holes (which looked like they had a stroke) cut for the driver, it was time to start glueing it all together with the help of Selleys Aquadhere. It was at this point that I noticed that matey at the builders merchants had given me warped plywood. Nice one, thanks. I'm too impatient to get it all done again so I figured that, as this is my first speaker project, I'd persevere and see how it goes.
Some Pictures from todays action:
Glueing the second piece (note the expensive water bottle weight)
Glueing down the baffle:
Glueing down the other side of the speaker. I needed this much weight to try and un-warp the wood
Sticking on the top piece of the speaker:
I'm using some pretty ropey speaker cable that came free with car speakers I bought for the Falcon, but that's easily changeable as I'm going for a binding post free design. Less connections the better.
The speakers still need the front fascia putting on which will be primed and sprayed Matt black as per my image above. I reckon this will look pretty good and I may be able to get away without veneering the speakers as the ply finish isn't too bad. We'll see.
In other news - I received a note that I have a parcel waiting for me at the post office All I need to do is to find a soldering Iron for 2 connections on my TK2050 amp and I'll be listening to music!
Total Noob- need some advice/ direction BigguyZ Solid State 10 6th August 2010 09:30 PM
Quick advice on which direction to take this build kgb_m3 Chip Amps 4 30th December 2009 04:45 PM
Tips/comments for upcoming 300B build xenithon Tubes / Valves 11 14th August 2008 12:48 PM
Grounds concept/direction/advice angchuck Chip Amps 5 5th March 2008 05:32 PM
need to build a transformer.... point me in right direction? AudioGeek Power Supplies 3 5th February 2005 02:37 AM
Copyright 1999-2017 diyAudio
