Need some direction/advice for upcoming build - Page 2 - diyAudio
Old 28th March 2011, 09:06 PM   #11
frugal-phile(tm)
planet10's Avatar
Originally Posted by zman01 View Post
would the micro towers be a project worth considering for Commited??
Certainly worth consideration
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th March 2011, 09:36 PM   #12
frugal-phile(tm)
planet10's Avatar
Originally Posted by Commited View Post
Will such a small driver deliver decent bass?
The EL70 in particular is a bass monster. It might not move as much air as FExx6, but it goes lower. If you need to play load put a pair in each box... reports from those building bipole Metronomes are that subs are being removed). The driver is versatile and not overly amplifier fussy (which the Fostex are)
Is an inverted BIB what it sounds like?
I assume an inverted BIB can be used with a 6.5" or 8" driver?
Flip it "upside down yes". And then you can use the alternate driver offset (which i understand has an edge on the standard one response wise -- not heightwise when used in a regular BIB.
I see no reason you couldn't invert a larger one, just have to worry about driver height
on what speakers I've liked in the past: B&W 602, B&W DM7Mk2, B&W 802 Matrix 3, System Audio SA1530, some of the KEF range and BBC Monitors.
It will be different, and potentially an eye opener.
Why is the hifimediy amp recommended for 4ohms when the Sure and Dayton TK2050 based amps don't specify this?
You'd have to ask them... may have something to do with the output LC filter... they really need to be tuned to the load.
dave
Old 29th March 2011, 03:05 AM   #13
Commited,
Fe166EN in the BIB is giving good bass after pushing them back to the wall and corner in my room. The bass is different from 3 way speaker bass I have previosuly expereinced. FE166EN in BIB bass quite tight and you can hear it clearly, and in my case it's there till 36 Hz (used a tone generator to check). But the bass does no have the typical slam or thud of a big 12" woofer... but I guess that's how the FR drivers behave. The sound from the midrange is very engaging and I fully agree with Dave, that's where the magic lies.
Dave, would the micro towers be a project worth considering for Commited??
-Zia
Thanks for the feedback! Would I be right in thinking that the smaller drivers in the BIB are a bit more room flexible and also supply a more lively sound?
I'm gathering from your enthusiasm about the driver that it's a pretty good "bang for your buck" then! I have read that someone got good results with the FR125's in a BIB with bass down to 40Hz. I'd imagine the speakers will go loud enough with the 50w available from the T2? I don't want my ears to bleed but it would be good to have a certain amount of flexibility.
How do the Mark Audio CHR-70 Mk1's compare? They're available as a pair for $99.
OK, I'll go and do a bit of research into the construction. I have read that you end up with the driver generally nearer the top of the speaker which sounds good to me aesthetically.
Does the opening on the bottom have to be a particular shape?
I don't doubt that for a second! I was in the realms of commercial speakers as I just didn't have the time or space to build some. Now I have both and no desire to spend big bucks on a compromise.
Old 29th March 2011, 03:47 AM   #14
frugal-phile(tm)
planet10's Avatar
Spend the extra $30/pr.
Here is an example, based on the FE126/127 recommended BIB at the time.
http://p10hifi.net/tlinespeakers/FAL...IBk-FE12xe.pdf (i really should tidy up the line weights)
I put a carlson slot on the back -- the idea being to help minimize ripple. If i was actually to build it, i'd put half of the slot on the sides (at the back) and make them by drilling small holes to make the pattern. One could start out small and grow it as necessary,
dave
Old 29th March 2011, 06:29 AM   #15
The Fostex Fe126's are the exact same price pretty much, with your experience, you'd lean towards the EL70s?
I must say that the idea of spending 1/2 as much and still being happy sounds appealing to me.
If I fire up google sketchup and do a rough design, would you be able to advise on the Carlton slot sizes?
Old 29th March 2011, 07:26 AM   #16
Ok, so I used the BIB calculator with a changed Zdriver value of .416 as recommended by Scottmoose. This has resulted in the driver pretty much exactly a metre from the ground which should work quite well as I'll add 25mm spikes to the bottom. This is a design for the EL70 driver.
Does the design look ok?
Old 29th March 2011, 08:18 AM   #17
frugal-phile(tm)
planet10's Avatar
There you go... we are eager to see build pictures and how it turns out.
Then you can start reading up on EnABL.
dave
Old 29th March 2011, 08:22 AM   #18
Dave, does that design look ok?
Any recommendations on carlson slot size?
Looks like I'll give it a go - quite different to my original plan but a cheaper way to get into my first DIY speaker build!
Old 29th March 2011, 08:29 AM   #19
frugal-phile(tm)
planet10's Avatar
The calculator has proven pretty good... start with it stock, using the method i proposed, you can grow carlson vents on the side if you fell that it is worthwhile experimenting.
dave
Old 29th March 2011, 08:41 AM   #20
Excellent. That's great Dave, thanks.
One more question - would be Mark Audio Alpair 7 be worth the extra $50 or should I just stop finding different options and order something!
And I just noticed that I somehow used the wrong values for my design, so I'll give it another go now. Balls.
Total Noob- need some advice/ direction BigguyZ Solid State 10 6th August 2010 09:30 PM
Quick advice on which direction to take this build kgb_m3 Chip Amps 4 30th December 2009 04:45 PM
Tips/comments for upcoming 300B build xenithon Tubes / Valves 11 14th August 2008 12:48 PM
Grounds concept/direction/advice angchuck Chip Amps 5 5th March 2008 05:32 PM
need to build a transformer.... point me in right direction? AudioGeek Power Supplies 3 5th February 2005 02:37 AM
Copyright 1999-2017 diyAudio
