Spawn Family Bruce BVR + FE206eN2(p10 fully enhanced). thoughts?
Old 25th March 2011, 06:09 AM   #1
xpheolix is offline xpheolix  United States
xpheolix's Avatar
Default Spawn Family Bruce BVR + FE206eN2(p10 fully enhanced). thoughts?
Hi all, I have been trying to settle on plans and drivers for awhile and think I may have a solid idea together. I'd like to build the Spawn Family BVR cabinet for the 8" Fostex Driver("Bruce"). Difficulty in the building of cabs is not really my concern as I have the skills and tools to do so. Also it seems a good idea to order the drivers from Planet 10 (I don't quite trust my skills in modifying drivers yet.) Ideally ordering the 206En fully modded w/ basket stiffening.
I'd be using 3/4 Birch for most of the cab and was toying with the idea of using a denser, more solid wood just for the baffle.
Every time I think I have a good idea of what I want to put together, something changes due to more research or another opinion. All help welcome! Thanks guys.
Old 25th March 2011, 08:46 AM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
That particular box is obsolete, which is why it's religated to the archives section (& will eventually be removed when we get around to updating the FH site). It wasn't all that well suited to the 206, being intended for its 207 stablemate. Of the free double-mouth designs on the FH site, Sachiko was the one for the 206.
Old 25th March 2011, 09:08 AM   #3
j3n2 is offline j3n2  Denmark
I tried bruce with fe206en(no mods) but ended up with fe206en in BiB/"bigger is better" BLHs.
The BiB's my favorit.
Old 27th March 2011, 06:14 AM   #4
jazbo8 is offline jazbo8
jazbo8's Avatar
Could you please elaborate a bit? What makes the BIB version better than the Spawn? better bass? better FR? ease of construction?...
Jaz
Old 27th March 2011, 06:33 AM   #5
TerryO is offline TerryO  United States
TerryO's Avatar
Jaz
As Scott has mentioned above, the Bruce was intended for a different driver, and it makes a great deal of difference. If the BIB was designed with the 206 in mind, which the Bruce wasn't, then it would just be a better fit and I would assume that the FR was a bit better.
The BIB would almost certainly be easier to construct, however I believe that with the proper driver in a bifurcated horn specifically designed for that driver, that one might expect that the horn would prevail.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 27th March 2011, 08:30 AM   #6
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
As a generalization:
Assumming the right driver in the spawn, a BIB will get better bass, at the expense of more ripple, requires a corner (or at least a wall) and is easy to construct.
The spawn will have more finese, and the edge in quality.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th March 2011, 12:03 PM   #7
Squeak is offline Squeak  Denmark
Squeak's Avatar
My experience though, compared with other multifold horns, is that with the BIB you can stuff your way out of most of the ripple while maintaining the edge in bass.
Old 27th March 2011, 12:09 PM   #8
jazbo8's Avatar
Great, thanks for the feedback, guys. I know these observations might be just generalization but wouldn't the Spawn with the same driver in a properly designed cabinet provide more bass since the design loads both the ceiling and the floor vs. the BIB's ceiling loading (again generally)?
Jaz
Old 27th March 2011, 12:19 PM   #9
Squeak's Avatar
Jaz
Unless the ceiling touches the top of the speaker, you are not going to get as much loading as from the bottom. The half of the energy emanating from the top will have slightly different tuning than the bottom and will therefore help to reduce ripple.
Old 4th April 2011, 03:45 AM   #10
xpheolix's Avatar
Thanks for the feedback! I would really like to construct one of the spawn double horns for a number of reasons, the difficulty in construction being one of them.
The plotted frequency response on the Sachiko build seems to have significant dips in the lower mid-range. Bruce has a smoother plotted response, as does Hiro by a bit. If this is the case I may want to sacrifice a bit of bass extension and step down to the 166's and construct a set of the Hiro cabs. I had planned on building a powered sub to augment the bass at a later date so this is not too much of a concern. Thoughts?
Spawn Family Bruce BVR + FE206eN2(p10 fully enhanced). thoughts?Hide this!Advertise here!
which Spawn Family member for these T&S? paba Full Range 4 19th November 2010 08:52 PM
Acurus P10 in need of help boy412 Analogue Source 15 6th July 2010 06:01 PM
this may be a stupid Q on Spawn Family paba Full Range 12 14th May 2009 12:01 AM
mikasa/spawn family/frugal horn lornie Full Range 11 15th June 2008 11:24 PM
Centre speaker to match Fe207E Spawn BVR OzMikeH Full Range 9 6th July 2007 12:10 PM
Copyright ©1999-2017 diyAudio
