Compact F.A.S.T. design
Old 17th March 2011, 06:37 PM   #1
rho is offline rho  Belgium
Default Compact F.A.S.T. design
I'm looking for a compact F.A.S.T. design. Something with a 6.5" bass driver and a 3" or 4" FR would fit my needs best I think.
I'm looking for a stand mounted speaker with maximum dimensions of about 25cm (10") wide, 45cm (18") high and 35cm (14") deep.
Anyone build anything like this?
Something with an SDX7 and FR125 would be very interesting.
But other design are very welcome too, obviously.
Old 17th March 2011, 06:55 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
SDX7 + FF85. Alpair 6 or Fountek FR88 or other 3" could be substituted.
A thread for Tysen and variations on FAST
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th March 2011, 07:17 PM   #3
I have read trough the Tysen thread already.
That's a nice design, but I'm a little afraid the -3dB on the SDX7 will be a little disappointing in such a small sealed box.
Does that config even work with a passive x-over? (don't have 4 amplified channels (...yet?))
Old 17th March 2011, 07:32 PM   #4
audiobomber is offline audiobomber  Canada
audiobomber's Avatar
Alpair 5 and SDX7, ported box
Alpair 5 / SDX7 Team | Markaudio
JX150NG and JX6HD closed box
http://www.ejjordan.co.uk/articles/J...ed_cabinet.pdf
I'm interested in seeing what else comes up in this thread.
Dan
Old 17th March 2011, 08:02 PM   #5
frugal-phile(tm)
planet10's Avatar
Originally Posted by rho View Post
the -3dB
You can always make the box bigger.
F3 is without menaingful correlation, look at F10. If you want a small box you will have to give up ultimate extension (Hoffman's Iron Law, extension, size, efficiency, you can only pick 2)
dave
Old 17th March 2011, 09:17 PM   #6
Yes, I kow there are limits to the bass extension in a smaller box. But 15 liter or a little more should be possible.
Why do you think F10 is telling more then F3? Does that have to do with room-gain?
Now that is really interesting!
Old 17th March 2011, 09:18 PM   #7
chrisb is offline chrisb
to answer the second question - at the XO employed in the Tysen ( circa 300Hz), passive high level would certainly be possible, but it's not hard to imagine that the cost of parts could be greater than the drivers, and their dimensions not tiny either
for example, the Jordan 2-way calls for 100mF HP cap to JX6, and the Mark Audio design's more flexible "anywhere from 200 to 5kHZ" ( personally I wouldn't waste the wonderful lower mid-range & upper mid bass of the Alpairs by crossing over any higher than 300) could range in values from 200mF on HP for 1st order to approx 100mF & 50mF plus chokes for 2nd order
altogether a very good justification for line level and active amplification, and how many of us don't have at least one ole SS amp or receiver lying around that wouldn't work for at least proof of concept on the woofers?
like my mind, this space intentionally blank
Old 17th March 2011, 10:08 PM   #8
frugal-phile(tm)
planet10's Avatar
Tysen is 17 liters. Once you get over ~14 litre stuffing can have greater effect than extra volume. 21 litre effective volume (Q = 0.5) is as large as you want to go
This is from Toole (Sound Reprodiution). F3 did not correlate with jusgements of extension of bass. He does have a tested metric that is (i'd have to go look it up)
dsve
Old 18th March 2011, 10:03 AM   #9
From other topics I noticed you prefer using the SDX7 in a sealed application. (and some disagree)
I intend to get as much bass-extension out of a small speaker and I'm not looking for an high SPL application. (I use a 6.5"mid-bass now with much less Xmax and never ran into problems)
I realize that the extra bass-extension comes with higher requirements towards Xmax, but I think the SDX7 has plenty.
Would a BR application be a good option in this case and if so, how much could I win going that route?
(in the meantime I'm considering a MiniDSP and fixing my chip-amp to go active)
Old 18th March 2011, 04:11 PM   #10
SDX7's X-max is not unlimited, and you'll definitely hear when it's exceeded. It's major appeal for us is the performance possible in very small sealed enclosures, which particularly suits applications like the Tysen, or multiple woofers for HT systems.
Compact F.A.S.T. designHide this!Advertise here!
Compact bookshelf design recommendation? kenny12 Multi-Way 24 23rd May 2009 09:00 PM
Compact TL design thoughts Larsp Subwoofers 0 23rd January 2007 12:20 AM
