Compact F.A.S.T. design
Old 18th March 2011, 06:36 PM   #11
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Chris touched on our use of SDX7. The SDX7 gives no warning of running out of excursion. You just get a very disturbing "fart" when the voice coil hits its stops. To avoid this one needs to use a sealed box, an aperiodic box (the TL we built had to get stuffed to aperiodic to avoid the ugly noises, or you need to actively filter below the tuning frequency of a "vented" box.
Remeber that when you look at how loe a woofer goes F3 is mostly meaningless, F10 is much more significant, and things will sounf better if the slope of the roll-off more closely matches the room gain,
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st March 2011, 03:15 PM   #12
rho is offline rho  Belgium
How big was the room and at what SPL did you get the bottoming-out of the driver?
Do you know what the F10 of an SDX7 in a 15 liter box is? (I migrated to linux, still need to find some good simulation SW)
Old 21st March 2011, 06:35 PM   #13
frugal-phile(tm)
planet10's Avatar
We have no issues with SDX7 bottoming when sealed. My room is pretty large, the amp we were using was running out before the speakers, max levels were louder than i usually listen to (bit not really really loud).
14 litre sims as Q = 0.58, F3 ~ 70 Hz, F10 ~ 33 Hz
The chart is from the SDX7 sealed doc, 3.5, 7, 14, 21 litre, Q = 1.0, 0.707. 0.58, 0.5
dave
Old 23rd March 2011, 07:38 PM   #14
Thanks for the info.
I think I'll have to put the SDX7 at the top of my shortlist then.
Compact F.A.S.T. designHide this!Advertise here!
Compact bookshelf design recommendation? kenny12 Multi-Way 24 23rd May 2009 10:00 PM
Compact TL design thoughts Larsp Subwoofers 0 23rd January 2007 01:20 AM
Copyright ©1999-2017 diyAudio
