Old 17th March 2011, 02:24 PM   #1
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Default My Bipole Aurasound NS3
Hi guys,
I have finally finished my sealed bipole speakers. Very unfortunately, they sound a bit too coarse and lacks details and precision. I am not sure if it's the drivers themselves, or the amplifier's not matching, or I am expecting too much from them. Anyway, I am posting some photos here.
I paid a carpenter to build the cabinets for me, so they look pretty nice.
The rear firing driver.
Old 18th March 2011, 07:17 AM   #2
borispm's Avatar
The speakers are 6"W x 7"D x10"H, and are built from 1/2" MDF. The internal volume is about 4L and I have a changeable bottom baffle. It can either be sealed or operate as bass reflex. The port has a diameter of 40mm and length of 120mm, with tunes it to about 70Hz, if I can remember correctly. I actually prefer the sealed cabinet. They are driven by a Marantz A/V receiver, and I suspect the 4ohm load of the speakers makes it somehow difficult for receiver. I am adding a 4ohm resistor just to see if it helps.
The drivers are not probably mounted too, they are just mounted by friction provided by some thick foam tape that I am using to "mod" the driver. Maybe this also accounts for the lack of resolution as there's no solid foundation for the driver to work. There are some more work to do too. The drivers and the binding posts are not soldered, and I hope proper connection will help a bit.
Old 18th March 2011, 12:45 PM   #3
borispm's Avatar
Sorry, I mean they are not properly mounted. Sorry for my bad English.
P.s. I added the resistor and they sound way better than they did yesterday.
New Aurasound NS3 2-way Timn8ter Multi-Way 18 16th November 2007 05:05 PM
Aurasound NS3-194-8E Mikael Abdellah Full Range 13 5th August 2007 04:51 PM
Aurasound NS3-193-8A mista2 Full Range 25 20th December 2005 03:37 AM
Anyone used Aurasound 3" NS3 widerange? morbo Multi-Way 15 19th October 2004 12:07 AM
Page generated in 0.07517 seconds (74.16% PHP - 25.84% MySQL) with 10 queries
