Critique my F200a design
Old 14th March 2011, 05:25 PM   #1
steviedon is offline steviedon  United States
Default Critique my F200a design
So.....been playing around in winisd. Before any slamming comes my way.....the goal here was to get good response in a large standmount monitor. I do understand that more extension can be had with this driver in a much larger cabinet......but just not possible considering space and overall room design criteria. Ended up with a 1.5ft3 quasi golden ratio ported cab tuned to 37hz....inside dimensions 14.25w X 8.25D X 22T. Provided the sim translates to the actual end result I think I've got something here......F3 of 42hz and F10 of 30hz respectively. Thoughts?
It is only rarely that one can see in a little boy the promise of a man, but one can almost always see in a little girl the threat of a woman. ~Alexandre Dumas
Old 15th March 2011, 11:44 PM   #2
I'm guessing the lack of feedback is due mostly to little subjective experience with this pricey driver. My only pertinent question I've yet to decide on is port diameter..........will going with a shorter 2" port introduce port noise? My logic says no, as the driver is not moving enough air to be of concern at only 2mm xmax.
Old 16th March 2011, 12:05 AM   #3
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
Given my experience using WinIsd, there's no reason why you shouldn't get decent bass response, unless the provided TS numbers are completely OTL.
Both boxes I've done turned out ok.
jeff
Critique my F200a designHide this!Advertise here!
Critique my first design bigwill Tubes / Valves 11 3rd June 2007 12:30 PM
critique my amp design please AudioGeek Solid State 6 26th February 2007 05:50 PM
Design critique MWP Digital Source 6 22nd August 2004 05:20 AM
Design critique MWP Chip Amps 6 20th August 2004 04:54 AM
Please critique this design.... Christof Multi-Way 22 10th January 2004 08:17 AM
Copyright ©1999-2017 diyAudio
