whizzer and intelligibility ?
All in all, I think I'm going to really like the Betsy's. They do have a very nice sound. I did have to cross the Hawthorne Audio Augies higher on them, but otherwise they are superior to the old EV's in every way but the looks (the EV's are eye candy). Tapping on the cones of both drivers was enlightening. The EV's have a papery sound, very noticeably so, with a touch of raspyness. The Betsy just gives a dull thud. Obviously, paper cone technology has improved since 1958.
The whizzers on the Betsy's are noticeably more extended and sound like they don't need any whizzer tweaks. I think someday soon I'll play with the EV LS12's and see if I can get a smoother high end out of those whizzers. It'd be a shame to just pack them away. Maybe I'll build a set of baffles for both drivers and rotate every so often. Be like getting brand new speakers again. :)
Dave:D
Wow, can't see the 3kz peak on the betsy shown in their graphs.
Well, I'm not on axis here. My baffles are aimed at a spot a couple of feet or so in front of me. It's been my experience that whizzer speakers sound better off axis a bit. I will do closeup measurements on axis soon (have to go get some stitches removed right now). One can't judge too much on one set of measurements at 12 feet away in a living room full of junk, err, interesting things. :)
Dave
Here are some measurements I took of a modified Coral Flat 8A about 8 years ago.
I also experimented with small foam adhesive strips stuck to the rear of the main cone near the perimeter, and this made a big improvement both to these drivers and a pair of Flat 8 Mk 2. Unlike coating mods the foam strips are easily removable, if you don't leave them on for months.... after that they do tend to bond fairly securely - 8 years later they are well and truly stuck and could only be removed by slicing them off.
Wow I'm glad to find this bit from DBMandrake, 2011! Over here in China, a fellow diyer on bbs.hifidiy.net "mogu1986" experimented widely before recommending the use of automotive "plast", the black stretchy heat-resistant tape for securing cables, to cover the front of a speaker cone to dampen resonance/breakup. The plast is extremely light and stretchy yet has a stiffness to it. I experimented with different coverage, back surface vs front of cone, etc., on some super-hard-space-age-material speakers: 6.5" resin-coated-carbon-fiber (a very poor man's Magico?) car bass/subwoofer, taking it to 7khz with no resonance peak and more fidelity than all my dome tweeters even Paradigm Studio beryllium (I had to use an electrostatic supertweeter); 4" fiberglass-honeycomb pictured here
https://www.diyaudio.com/community/threads/1-order-crossover-help.391332/page-2#post-7151405
A small "whizzer" helps it go tweeter-less, as well as XO-less with an 8" upfiring driver of the same make (dubbed "LXmidi"). The resin-coated-CF plast-job has a rosette as well that I think helps with dispersion. Eventually I added a vintage alnico 4x7 and dubbed the unlikely MTM (with electrostatic ST and CF-resin sub-bass-to-7khz) "Ultrae" for ultra-sultry. More recently, I added plast whizzer to the dustcap-edge of a 4" Michael's Audio/Hifi-Bird/Isred(?) purple-drum-paper-cone FR (dubbed "Blacktulip" in pianoblack T'Lonken), and plast wave-guide around a ceramic-dome car-tweeter (very poor man's Accuton) held over the dustcap area of a 15" wide-range-to-4.3khz (dubbed "Axia"). Besides adding 1-2dB very HF, I think/hope the main cone HF dispersion is improved too.
Early snapshot of resin-coated-CF subwoofer (Juecass 658). The "plast rosette" grew around the dustcap area (without touching it or boom!) nulling cone breakup/resonance. After 0.6mH 1st-order LPF at ~1khz, flat to 7.5khz no audible distortion. (Use of plast, credit to mogu1986 of bbs.hifidiy.net.)
