Hi
Anyone have any plans for useing the CSS FR125SR for a center channel? I have 2 of these that id like to build a center channel. Any ideas how I might build one? Thanks Ron |
#2 | |
Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#3 |
Hi
Do you know what the sizes are that I need to cut? Id like to put both drivers in the same cabinet if I can? Thanks Ron |
#4 |
frugal-phile(tm)
On going experience with FR125 has me liking each driver in 4.5 litre (aperiodic) up to 7 litre sealed or aperiodic.
What Terry said about using 2, bipole or if frount firing as close as possible arrayed vertically. Do noy put them side by side unless you turm it into a 1.5 way dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 | |
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application Last edited by TerryO; 13th March 2011 at 04:18 AM. |
#6 |
frugal-phile(tm)
#7 |
I had wondered if you'd had a different idea and that influenced the decision.
Turns out we're evidently in the same boat...again. ![]() Best Regards, TerryO
#8 |
Well no I have no idea what to do now.
Ill just go ouy and buy one. Thanks Ron |
#9 | |
What is it that's confusing? You now mention going out and buying "one". I thought you already had two drivers, or do you mean enclosure? Now I'm confused, TerryO
#10 |
frugal-phile(tm)
You'd have to "double" all the cabinets for 2 units.Personally, i'd see 1st ig you can get away with 1 driver.
7 litre vented To make it aperiodic play with open-cel foam in the slot. Sealed. Box size can vary alot. 4 litre aperiodic -> ![]() and the variation we built dave
| Need center channel help | Ryan_Mc | Multi-Way | 0 | 12th February 2009 03:36 AM |
| center channel?? | wicho | Multi-Way | 1 | 25th October 2008 01:01 AM |
| Center channel | 66Panel | Multi-Way | 0 | 25th August 2008 03:48 AM |
| center channel | sidd_raj2002 | Multi-Way | 14 | 4th December 2004 02:41 PM |
| Center Channel | wigginjs | Multi-Way | 6 | 26th October 2004 01:48 PM |
| Page generated in 0.10062 seconds (83.48% PHP - 16.52% MySQL) with 10 queries |
