I shd have said breakup rather than harshness- hence why I thought maybe a shaped sponge phase plug might help if glued onto the '92.
ultrakaz I'm a big fan of the smaller 60mm jordan driver, will give the larger new A10s a try and see how they compare at the top end, shd be interesting.
I will give the larger new A10
Not much bigger. The Sd (for T/S calculation) of JX92 is 85 cm^2, A10 is 89 cm^2
dave
dave
what i meant was the smaller jordan, jx6hd or whatever its called
yes, apples to apples ....
I can never remember the suffice either. Like to hear that one. Probably comarable size wise to Alpair5.
dave
The 60mm Jordan has to be better than the A10 at the top end or the Jordan is broken. The A10 not matter how well designed cannot defeat the laws of acoustic physics. And it may well be "better" in some ways than the JX92s (I don't know), but looking at the frequency response graph it trades off a rising top end for improved off axis response. You will still be listening to cone breakup massaged and disguised by clever design. It is too big to give resolution of music at the top end, not just extension as seen on a graph via test tones. Alas, there is no free lunch. Why not simply seal the Jordan 6 and roll in the JX92s at the -12db point?
Its all a trade-off at the HF's
the jxr6 is a gem of a driver but needs a simple crossover, the bigger A10 needs no crossover which must help.
edit: saw this design using the first gen A10..is the colour a 'special' and are the specs correct? http://www.eng.sup-audio.com/html/full_range.html
Except for the bit about it being a BR, the specs are in line with A10.1 data. The tall-slim shape and )looks like) port out the back bottom are going to make this an ML-TL
dave
Gold colour was a standard finish.
I had a set of gold A6 thru here. It is a very nice colour.
The current "gold" is really copper, and derived, i believe, from an effort to make CHR that matched the colour of the phase plug in the SDX7. I rather like it.
dave
Loud enuff for me in most cases in my room.
These drivers in mMar-Kel6 (before treatment) got a lot of attention at last years fest. They, to my mind, aren't as good as the A6p protos i have now in that box, so the production units (metal & paper should be a big improvement)
I also used them FR with a pair of powered SDX7 woofers coming in under them. Quite satisfying
dave
dave
dave
dave
I like the alpairs but the only issues (for me) are SPL's and the huge diameter baskets which spoil the cabinet design I wanted to use them for. The new alpair 6 on winisd shows an f3 of 55 hz, pretty impressive (did I make a mistake?). Would like to use these in a desktop TL, but will have to somehow trim the basket diameter down. Not sure how.
what are the correct specs for gen 2 alpair 6? I have seen 2 different ones.
per post on Mark Audio forum here:
Alpair 6M parameters:
Driver 4.0 Ohm
Revc 3.60 Ohm
Fo 63 Hz
Sd 36.3 Cm²
Vas 4.8 Ltr
Cms 2.58 m M/N
Mmd 2.48 g
Mms 2.57 g
BL 2.81 T·M
Qms 2.76
Qes 0.45
Qts 0.38
Levc 128.7 uH
No 0.243 %
SPLo 85.4 dB
Xmax 5.2 mm (1 way)
Power 15 watts nom. 30 Max
Coil 18-mm dia. Alu-copper
I'm not sure if /where he's published specs for A6P paper - presumably at least several will be slightly different
https://www.madisound.com/store/manuals/Alpair 6P Gen.2-A.pdf
https://www.madisound.com/store/manuals/Alpair 6M Gen.2-.pdf
Specifications for both units are also displayed on the madisound site, Blue Planet & presumably other main dealers (I only checked those).
Driver 4.0 Ohm
Revc 3.60 Ohm
Fo 63 Hz
Sd 36.3 Cm²
Vas 4.8 Ltr
Cms 2.58 m M/N
Mmd 2.48 g
Mms 2.57 g
BL 2.81 T·M
Qms 2.76
Qes 0.45
Qts 0.38
Levc 128.7 uH
No 0.243 %
SPLo 85.4 dB
Xmax 5.2 mm (1 way)
If this is right, then the old spec A6 goes much lower. With these specs I'm getting F3 65 hz optimum on winisd
old spec A6
vas 3.3
qts 0.48
fs 74
86 db (better) F3 55 hz optimum (far better)
1st off the old A6 needs to be compared to A6P. A6M is optimized for smaller boxes (will work in 1.5 litre!!).
Sometimes WinISD "optimums" are not, What box volumes and tunings?
The results are comparable. A6P will work in larger box and can go a bit lower, It is more efficient (from spec), i'll let you know how they measure once they come off the break-in bench.
T/S and sims don't speak at all to the lage sonic improvements with the new drivers (an assumption based on proto A6P and the differences on the larger drivers with similar improvements.
dave
dave
I'm wanting to compare just the metal 6, old version and new one. It is a big spec difference(if correct) and winisd should be ok for simple comparisms like this
You're not really comparing like with like though; the design objectives of the Gen1 & Gen2 units are not quite the same. Maximum LF extension was not the goal with the latter; improved compensation for step loss & linearity were the main goals, plus the ability to be squeezed into smaller cabs.
Incidentally, I wouldn't recommend trying to trim down the basket. You'll severely damage its structural integrety.
- Full Range
- Alpair or Jordan
