Alpair or Jordan
Alpair or Jordan
Old 17th March 2011, 08:46 PM   #21
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
I shd have said breakup rather than harshness- hence why I thought maybe a shaped sponge phase plug might help if glued onto the '92.
ultrakaz I'm a big fan of the smaller 60mm jordan driver, will give the larger new A10s a try and see how they compare at the top end, shd be interesting.
Old 17th March 2011, 09:06 PM   #22
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Alpair or Jordan
Originally Posted by Bill poster View Post
I will give the larger new A10
Not much bigger. The Sd (for T/S calculation) of JX92 is 85 cm^2, A10 is 89 cm^2
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th March 2011, 10:10 PM   #23
dave
what i meant was the smaller jordan, jx6hd or whatever its called
Old 17th March 2011, 10:12 PM   #24
chrisb is offline chrisb
yes, apples to apples ....
kinda burnt out - taking a break
Old 17th March 2011, 11:04 PM   #25
frugal-phile(tm)
planet10's Avatar
Alpair or Jordan
I can never remember the suffice either. Like to hear that one. Probably comarable size wise to Alpair5.
dave
Old 18th March 2011, 02:10 AM   #26
ultrakaz is offline ultrakaz  United States
The 60mm Jordan has to be better than the A10 at the top end or the Jordan is broken. The A10 not matter how well designed cannot defeat the laws of acoustic physics. And it may well be "better" in some ways than the JX92s (I don't know), but looking at the frequency response graph it trades off a rising top end for improved off axis response. You will still be listening to cone breakup massaged and disguised by clever design. It is too big to give resolution of music at the top end, not just extension as seen on a graph via test tones. Alas, there is no free lunch. Why not simply seal the Jordan 6 and roll in the JX92s at the -12db point?
Old 19th March 2011, 01:17 PM   #27
Its all a trade-off at the HF's
the jxr6 is a gem of a driver but needs a simple crossover, the bigger A10 needs no crossover which must help.
edit: saw this design using the first gen A10..is the colour a 'special' and are the specs correct? http://www.eng.sup-audio.com/html/full_range.html
Old 19th March 2011, 01:42 PM   #28
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
That's a Gen.1 unit.
Gold colour was a standard finish. Can't see any specs. on that site to check I'm afraid, other than impedance, sensitivity & max powerhandling, all of which are to be found on the manufacturer data sheet.
Old 19th March 2011, 11:51 PM   #29
frugal-phile(tm)
planet10's Avatar
Alpair or Jordan
Except for the bit about it being a BR, the specs are in line with A10.1 data. The tall-slim shape and )looks like) port out the back bottom are going to make this an ML-TL
dave
Old 19th March 2011, 11:57 PM   #30
frugal-phile(tm)
planet10's Avatar
Alpair or Jordan
I had a set of gold A6 thru here. It is a very nice colour.
The current "gold" is really copper, and derived, i believe, from an effort to make CHR that matched the colour of the phase plug in the SDX7. I rather like it.
dave
Alpair or JordanHide this!Advertise here!
alpair/jordan fullrange vs pluto linkwitz fxs Full Range 26 21st February 2011 09:07 PM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 06:04 AM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 07:14 AM
Jordan JX92S from EAD or Mark Audio Alpair 10? ilwooz Full Range 56 20th March 2010 02:26 AM
