Old 9th March 2011, 08:45 AM   #1
Jameslc is offline Jameslc  Australia
Default Coral 4A-70
Hi all does anyone has the VAS for these speakers i can't find it anywhere
Old 9th March 2011, 08:55 AM   #2
Brisso57's Avatar
Here's some info ...
CORAL FX-1
cheers
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 9th March 2011, 09:02 AM   #3
yeah i know all of the qts,qes etc but i just wanted to know the vas for winisd
Old 9th March 2011, 09:02 AM   #4
Brisso57's Avatar
& some more from here: Vintage SpectrumAudio
Coral 4A-70 11,4cm*4/8/16Ohm*40Watt*SPL90dB*Fres85Hz-20kHz*Qts0,42*2,7g*Textilsicke*Gußkorb
cheers
Doug
Old 9th March 2011, 09:09 AM   #5
Manufacturer: CORAL
* Model: 4A - 70
* f(s)= 121.10 Hz
* R(e)= 6.90 Ohms
* Z(max)= 27.10 Ohms
* Q(ms)= 2.455
* Q(es)= 0.838
* Q(ts)= 0.625
* L(e)= 0.19 mH
i have got all these from another forum but considering 2 days worth of research and i still can't find the vas i might have to calculate it
Old 9th March 2011, 09:23 AM   #6
But i don't know how lol
Old 9th March 2011, 09:35 AM   #7
Brisso57's Avatar
CORAL FX-1
cheers
Doug
Old 9th March 2011, 11:29 AM   #8
Very good drivers - don't stuff about with guesswork - get them professionally tested - well worth the cost and effort.
... jh
Old 10th March 2011, 02:32 AM   #9
I was thinking of getting a woofer tester that plugs into the computer and finding the specs that way because i don't think there are any commercial speaker testers in Hobart
Old 10th March 2011, 04:10 AM   #10
Send them over here to Melb - quite a few places will do the full test, including w/fall, transient, FFT,etc, etc - not really a problem if you have the original or good travel boxes for them.
Lorrantz Audio will also do a suitability/use/evaluation on their big computers if you can tell them what you want to use them for and develop "optimax" box parameters for you too, etc
... jh
Coral 10" cast aluminum frame woofers, pr $70 jmillerdoc Swap Meet 0 2nd March 2011 05:00 PM
FS: GM70 ( GM-70 ГМ-70 ) Russian audio triode radiostar Vendor's Bazaar 0 23rd February 2011 06:12 PM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 01:42 AM
FS: Coral alnico 6 inchers and Coral H-12c alnico tweeters MichaelPublic Swap Meet 2 27th June 2008 11:24 PM
Data on Coral 12L-70 Test Pilot Multi-Way 0 24th October 2002 02:53 PM
Page generated in 0.09856 seconds (77.13% PHP - 22.87% MySQL) with 10 queries
