Old 6th March 2011, 06:41 PM   #1
Default absorbent material ?
Ok, I'm in the process of final sanding/finish work on a pair of Fostex FE206e BLH cabinets. I know about most of the home brew upgrades.
My question is would 1/2 to 3/4 eggcrate foam serve as "absorbent material" for the compression chamber?
BTW I am planing to build the Sachico horns next. The Fostex horns sound better than anything else I have listened to-I have no NEED for reams of graph paper to make me like them.
Thanks all.
Old 6th March 2011, 09:47 PM   #2
Speakerholic
Cal Weldon's Avatar
Eggcrate plus fiberfill?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 6th March 2011, 10:27 PM   #3
bear's Avatar
No, imho. Eggcrate foam or almost ANY other foam is an inferior sound absorbing material.
Of course a lot depends on what you want to "absorb"?? And, how much you want to absorb (ie. how many dB at what frequencies).
There are published graphs for absorptive materials.
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 6th March 2011, 10:59 PM   #4
Greg B is offline Greg B  United States
Eggcrate foam IME causes too much damping if located near a driver, and it is likely to sap the subjective dynamics. It may sound good if the speaker is only to be played very loudly.
Carpet pad is a better choice for a fullrange driver IMO.
YYMV of course, and it's possible it might work in some situations. Experiment and see for yourself.
Old 6th March 2011, 11:09 PM   #5
I was lucky enough to find some wool felt for my project and it worked well. You could also get some 1/2" or so acoustic fiberglass ceiling panel material. Cheap and effective. Use yellow carpenters glue to fix it inside your cabinets. Start with the back, front and one side. If you need more you can add some pillow batting through the driver cut outs.
Old 7th March 2011, 01:51 PM   #6
Thanks all
SSB4 reflex project: massive amount of rear wall absorbent!!! mondogenerator Multi-Way 2 5th November 2009 11:09 PM
Damping material. bmxsummoner Full Range 0 21st August 2009 09:18 PM
Cabinet construction started - additional absorbent internal layers? quickshift Multi-Way 8 26th February 2007 08:08 PM
Sound absorbent lining for reflex enclosures kimbo Multi-Way 6 3rd April 2005 09:41 PM
Rolling off woofer with HF absorbent material in front of it. Circlotron Multi-Way 17 29th June 2002 05:15 PM
Page generated in 0.07404 seconds (73.88% PHP - 26.12% MySQL) with 10 queries
