Modifying Markaudio Pensils
Old 8th March 2011, 05:26 PM   #11
mahleriana is offline mahleriana  France
OK it's clearer now (sometimes understanding every word in english is not so easy...i'm french
Thanks scottmoose !
Old 9th March 2011, 01:31 PM   #12
Squeak is offline Squeak  Denmark
Squeak's Avatar
Wouldn't it be possible to simplify the Pensils even further by simply leaving out the bottom of the box, raising the speaker a bit from the floor with small feet to get the same "port" area?
Old 10th March 2011, 05:32 AM   #13
Squeak's Avatar
In case anyone was confused, my suggestion was exactly what is illustrated in the article in this thread: Rex Baldock Trike (Voigt pipes) HFN&RR 1961.
So I guess my question is essentially does the port in have directionality that is advantageous and is any passive radiator/air plug, like a regular BR, taking place in the shallow port?
Old 10th March 2011, 05:43 AM   #14
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
In theory that should work... the vent height would be about ~4.23mm. You'd have to shorten the internal box heght and you;d have to space it off something solid.
You would have a dramatically higher vent aspect ratio which will effectively add an R to the vent and change the nature of the tuning.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th March 2011, 06:55 AM   #15
Squeak's Avatar
dave
You mean I get some reflex loading, even with such a very long port? It didn't seem Rex needed shorter pipes. On the contrary his was quite long plus the halfway-pipe. But then he only had empirical observations to rely on...
Old 10th March 2011, 07:24 AM   #16
frugal-phile(tm)
planet10's Avatar
The vent is the restricted terminus of the transmission line. Rex's design is something completely different
dave
Old 10th March 2011, 08:50 AM   #17
Squeak's Avatar
dave
They are? They seem quite similar to me. Both are lines, only with different amounts of taper. Rex's might not be calculated in hight to resonate at some specific opportune frequency, but it will still resonate and it still has a smaller terminus than the cross-section of the end of the line (in the article he says 40 percent smaller).
Modifying Markaudio PensilsHide this!Advertise here!
MarkAudio now at Madisound Tom V Full Range 25 6th July 2010 07:14 PM
5.1 system with Markaudio drivers? Rick J. B. Full Range 17 4th January 2010 05:53 PM
alpair 5 from markaudio _henry_ Full Range 39 17th August 2008 07:32 AM
