diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   MLS Vs Sweep (http://www.diyaudio.com/forums/full-range/184400-mls-vs-sweep.html)
Aucosticraft 4th March 2011 01:21 PM
MLS Vs Sweep
1 Attachment(s)
I measured my satellite speakers. with MLS and Sweep frequency. The readings above 500Hz are much identical but starts making difference below it. What could be the reason? which of the two is more accurate?
Attached : Pic of the measurement.
Elias 4th March 2011 08:01 PM
Let me guess, the blue one is with mls?
- Elias
Aucosticraft 5th March 2011 06:30 AM
Originally Posted by Elias (http://www.diyaudio.com/forums/full-range/184400-mls-vs-sweep-post2491536.html#post2491536)
- Elias
Why guess? its clear on the lower left side of graph.
Well, no one here has answer?
Svein_B 5th March 2011 06:51 AM
The sine-sweep is usually the one to trust.
Ivo Mateljan, the crator of ARTA, has made some study of this subject, published here:
ARTA Support
Look at: "The Comparison of Room Impulse Response Measuring Systems, Proceedings of the First Congress of Alps Adria Acoustics Association, Portoroz, Slovenia, 2003."
SB
Elias 5th March 2011 11:02 AM
:D I checked the graph in a hurry, but it was clear which one is which.
Basic mls has poor signal to noise ratio at low frequencies because it has white spectrum. Log sweep has bass boost of 10dB/decade so SNR is better at bass. Mls can use pre-emphasis to increase low frequency SNR, but I don't know if your sofware has it or not.
- Elias
Originally Posted by Aucosticraft (http://www.diyaudio.com/forums/full-range/184400-mls-vs-sweep-post2492096.html#post2492096)
Aucosticraft 6th March 2011 12:28 PM
ok.... Thanks Svien and Elias,
So the conclusion is sweep is better with S/N at lower frequencies.
am I right ?
Resources saved on this page: MySQL 18.75%
