Old 3rd March 2011, 05:26 PM   #1
Default A hole in the suspension
Hi, a crying man is writing. May be it is an OT in this section, anyway these are the facts.
Screwing a Tang Band W4 on cabinet the screw driver slides making a hole in the cone suspension. It is 10 mm length and 5 mm width, I have the piece of detached rubber.
Can I do anything to repair this damage?
Many thanks to all of you
Ziocalepino
Old 4th March 2011, 04:38 AM   #2
Here is a picture of my damage
Old 4th March 2011, 04:51 AM   #3
I canīt see the pic :/
Old 4th March 2011, 06:06 AM   #4
AEIOU is offline AEIOU  United States
AEIOU's Avatar
Send a message via AIM to AEIOU Send a message via MSN to AEIOU Send a message via Yahoo to AEIOU
Ziocalepino
I've repaired damaged surrounds using black RTV silicone. First I align the break/tear with masking tape and then use a small brush to apply the silicone. Masking tape goes on the outside and the RTV silicone is applied from the inside, underside. After the silicone dries, carefully peel away the masking tape.
RTV silicone tends to be thick, but it can be thinned with a little bit of Lacquer Thinner.
Sometimes I've wanted to apply RTV silicone with syringe for pinpoint application. I squeeze out a lot of silicone into a throw away container, stir in Lacquer thinner as needed and then when the mixture is uniformly thin I pour the mixture into a disposable hobby syringe.
Old 4th March 2011, 06:37 AM   #5
frugal-phile(tm)
planet10's Avatar
That is quite a hol. You can patch it, but it will nevr be the same. Start saving up for a replacement. You should try to fix it (i'd use the RTV, to glue the piece back in) and put it to a less critical use.
I always practise safe screw driving when installing drivers,
1/ drill a pilot hole.
2/ practise safe screwing. Always place you habd such that th screwdriver puts a hole in your hand, not the driver -- your hand will heal.
3/ Do not use slot or Philips scres. Hew or Robertsone are a lot harder to make slip.
4/ no powerscrew drivers.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th March 2011, 06:48 AM   #6
Send a message via Skype™ to Rullknufs
I have done the same thing, not on my driver but in a shop i was "working at" for a week. They didn't find out about and it was the last week. I used a machine screwdriver and slipped at put it straight through the suspension
When i screw close to drivers, and other things you got to be careful with, i always place my hand around the screwdriver so it can only move up, down or around. If i would slip it would be stopped by my hand. I prefer to get a little hole in my hand rather that putting it straight through a driver
Old 4th March 2011, 06:55 AM   #7
AEIOU's Avatar
dave
Practice safe screwing? Avoid STDs!
Old 4th March 2011, 07:32 AM   #8
frugal-phile(tm)
planet10's Avatar
Originally Posted by AEIOU View Post
STDs!
Sucky Torn Drivers?
dave
Old 4th March 2011, 05:16 PM   #9
Bob Brines's Avatar
I agree wholeheartedly. Never, EVER use a slotted screw and Phillips only under diress. I use either Robertson or Allen heads. I disagree about power screw drivers though. I just feel more secure holding the handle of my 12v power driver.
Bob
Old 4th March 2011, 05:46 PM   #10
chrisb is offline chrisb  Canada
Bob
I'm with ya there Bob - just remember to pilot drill and set the torque clutch gingerly when using brass screws.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
what suspension? davecooper Analogue Source 12 13th October 2010 09:59 PM
Acoustic suspension dan stanton Multi-Way 9 12th February 2010 08:40 PM
fs3 suspension phildcamp Subwoofers 4 29th October 2008 11:29 AM
Suspension collapsed davidsrsb Analogue Source 4 26th January 2006 07:06 PM
Suspension Grommets JonesS Analogue Source 2 17th November 2005 01:20 AM
Page generated in 0.11352 seconds (79.56% PHP - 20.44% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
