Old 28th February 2011, 03:19 AM   #1
Default Alternative driver choices for Changs
If I build a set of Changs, are there any suitable drivers that might replace the Fostex FE207e or Pioneer B20 drivers listed? Also, I sent an email to David at frugalhorn.com to pursue getting the plans for the Curvy Changs. I received no reply. Is there a different email address than the one which comes up if you select the "by request" under the Curvy Changs?
Old 28th February 2011, 05:35 AM   #2
Though relatively unproven this GRS branded driver seems to be a clone of the pioneer.... @ $12.50 a piece they're worth a shot.
GRS 8FR-8 Full-Range 8" Speaker Pioneer Type B20FU20-51FW
You might try to PM David through the forum. He might even still have some 207's kicking around.
You could try this, although a bigger hit to the pocketbook. I think Bob Brines is now using it to replace the 207 in his large bookshelf, with only mods to the BSC circuit.
Tang Band W8-1808 8" Neodymium Full Range Driver
It is only rarely that one can see in a little boy the promise of a man, but one can almost always see in a little girl the threat of a woman. ~Alexandre Dumas
Old 28th February 2011, 06:00 AM   #3
Hey, thanks for responding so quickly. I'll probably go ahead and order a pair of the Pioneer's and get started on the project for now. I'm guessing someone here has put together a pair of these and has experimented with different sets of drivers for them. If these drivers don't sound very good I won't have spent too much money one them. Do you think these enclosures be fairly forgiving if the drivers aren't an exact match to the suggested pairs? I currently own Martin Logan Request, Klipsch Heresys and Klipsch Cornwalls. I have an Outlaw preamp and Sunfire Cinema Grand I drive the MLs with in my home cinema setup. I am setting up a different home cinema area in my home and kind of got the idea of building a set of fronts as a project just for fun. I'm going to build a folded horn subwoofer as well (not needed I'm sure).
Old 28th February 2011, 06:15 AM   #4
frugal-phile(tm)
planet10's Avatar
You have mail. (note: it is frugal-horn.com)
You are on your own at this point on choosing drivers for the Changs with discontinued drivers. The BOFU and HA FR8c are already substitutes.
You want to look for drivers with Fs, Qts, and Vas similar to FE207. Keep in mind that the spread on the FE207 was as much as 20%
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th June 2011, 04:08 PM   #5
Location: Mississippi, where good music comes from, or used to anyway
Well, I plan to build the Curvy Changs this weekend or next and I'll be using the GRS 8FR-8 and maybe a Goldwood GT-302/S for the highs. I may also build a set of half changs using the same driver sets. I'll keep everyone posted.
Driver choices for 2-way with most bass extension percy Multi-Way 16 21st September 2010 09:12 PM
Kids' Boombox Driver Choices CarlosT Multi-Way 8 19th December 2006 07:24 PM
Educational speaker driver choices? Few Multi-Way 7 21st March 2006 11:31 PM
Advice on a couple of different driver choices please :). quickshift Multi-Way 1 11th August 2005 07:21 PM
Peerless Driver Choices Woe fishball79 Multi-Way 11 5th July 2003 11:56 PM
Page generated in 0.08956 seconds (78.04% PHP - 21.96% MySQL) with 10 queries
