Another pair of FONKEN PRIMES
Old 26th February 2011, 02:31 PM   #1
Decca is offline Decca  United Kingdom
Default Another pair of FONKEN PRIMES
Hi All,
I'm new here and thought I'd share my recent Fonken build with you all.
I got the FE127en drivers from Dave at P10 and the cabs were built as recommended in 1/2" birch ply, 3/4 for front baffle. Joints were 1/2 lapped for extra surface contact for the glue. Boxes built and then the champher was cut in one pass on bench saw. Rebated the cab top and bottom so the brace slides in to meet the back of the drivers. My router and table saw did most of the hard work.
All internals are lined with 12mm dense wool fabric. Speakers are sat on the wool in one of the pics below.
Finished with 2 undercoats and 3 coats of white diamond/eggshell. The champhered edge has 6 coats of clear satin laquer.
I built some simple stands to match. 500mm long - M12 threaded rods through a 38mm flag. The top is MDF which is countersunk to accept the nuts on the rods. And that's about it.
Only had chance to give them a quick workout but will post my impressions once I've had an extended listen this weekend.
Here's a few pics.......
Old 26th February 2011, 02:57 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Nice, thanks for posting.
Note about posting photos:
http://www.diyaudio.com/forums/blogs...ges-forum.html
Thank you.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 26th February 2011, 03:46 PM   #3
doorman is offline doorman  Canada
doorman's Avatar
Nice job Decca! They are certainly a fun build, and the tight, controlled bass is special IMHO.
High WAF too!
Thanks for posting.
Don
Old 26th February 2011, 04:16 PM   #4
High WAF too!
Thanks for posting.
Don
True about the bass, very well defined and cleaner than my old 6.5" floorstanders, although my initial listening suggests I may need to add a little reinforcement with a sub in the future. Nothing earthquaking but a little more bass warmth would help to my ears.
Massively high WAF and was the reason I chose the Primes.
Old 26th February 2011, 04:55 PM   #5
loninappleton is offline loninappleton  United States
Outstanding. I always appreciate clear pictures of things I've considered building but held off on because computer drawings don't give enough information.
Currently working on assembling a K12 Karlson.
Old 26th February 2011, 06:00 PM   #6
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Very nice Allan.
I'd suggest something that is not a sub per se. A good midbass -- there are tons of those -- that has good response up to at least 1k. Gives up some on the bottom, for good integration with the Fonken.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th February 2011, 06:21 PM   #7
SunRa is offline SunRa  Romania
Very nice build. I am thinking more and more often to a Fonken. I would do only two "improvements" to this design. I would try to round-over the sharp edges (it's already great the angle with the baffle is 45, not 90). I think this would also contribute positively to the looks of it, not only help diffraction. And second, I would definitely try to bury the frame of the 127 in the baffle.
Old 26th February 2011, 07:32 PM   #8
aptquark is offline aptquark  United States
aptquark's Avatar
Originally Posted by planet10 View Post
Very nice Allan.
I'd suggest something that is not a sub per se. A good midbass -- there are tons of those) that has good response up to at least 1k. Gives up some on the bottom, for good integration with the Fonken.
dave
Heck of a build! Dave, what's the bottom end on those suckers?
And, when you say midbass, is that just a sub but with midbass characteristics?
Old 26th February 2011, 07:39 PM   #9
Thanks for the info Dave,
I'd appreciate more info on the mid bass option you describe too.
I've a couple of redundent 6.5" woofers I could use with the right cabinet or do you have any recommendations that you could supply and or/ cabinet designs or links ?
They will need to be powered seperately I imagine ?
Old 26th February 2011, 07:55 PM   #10
Jim Shearer is offline Jim Shearer  United States
Jim Shearer's Avatar
I think that depends on the room and the amp. I built a pair of FE127e Fonken Primes. In my (13.5'x16') room connected to a 1972 vintage Sansui 4000 receiver, the SPL at 40 Hz is the same as at 200 Hz when played at moderate levels (85 dB peaks). Below 40 Hz it drops like a stone. I think Dave rates them as hitting 60 Hz--but he seems to like tubes and has (IIRC) a larger room. As always: YMMV.
Cheers, Jim
A day without music is like a day without food.
Another pair of FONKEN PRIMESHide this!Advertise here!
New Fonken pair is born. Netlist Full Range 366 21st January 2017 11:15 AM
FS: A pair of Fonken speakers xecluded Swap Meet 4 12th July 2010 08:58 PM
one Fonken down, one to go... cjkpkg Full Range 7 25th September 2009 02:24 AM
fonken build mantisory Full Range 16 26th August 2008 04:39 AM
Copyright ©1999-2017 diyAudio
