Help with BR design for CHP70
Old 28th February 2011, 06:19 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I get 111 mm long. A mm is't going to make a big diff.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th February 2011, 06:24 PM   #22
frugal-phile(tm)
planet10's Avatar
Originally Posted by planet10 View Post
I will be doing a version of the Mar-Kel70 for the CHP.
A quick check suggests that CHP will work in Mar-Kel70, but that a slightly lower port tuning would be needed to optimize it (not much thou)
dave
Old 22nd March 2011, 09:29 AM   #23
Gropascal is offline Gropascal  France
Hello dave,
"A slightly lower port tuning". How can I translate this in port dimensions ?
Longer ports, enlarged port surface ?
I am thinking of building Mar-Kel, increasing ports height, allowing for tweaking by addition of wooden pieces in the ports.
Is this way the correct one ?
Thanks for your advice
Old 24th March 2011, 01:11 PM   #24
mahleriana is offline mahleriana  France
Here are the sims in post 2 plus a couple sealed (the small sealed would be fine for surrounds for instance -- if you can actually fir the driver in that small a box)
dave
Dave,
In the graphs shown with yout software, the maximum excursion lines are calculated for the max input for this driver (18w ?)
Old 24th March 2011, 07:09 PM   #25
frugal-phile(tm)
planet10's Avatar
Excursion by default is at 1w in. I usually leave it there, Power ratings on drivers for home use are largely irrelvent so i don'y pay attention to them
dave
Help with BR design for CHP70Hide this!Advertise here!
Best slam and punch in the bass for hifi (not PA): TH with 15 OR 2x15 BR OR 1x18 BR? pk Subwoofers 29 8th July 2013 08:51 PM
Will this design work for a LM3886 100w BR amp?? Minion Chip Amps 4 19th October 2007 04:16 PM
BR Box design please help. GregGC Multi-Way 14 24th February 2004 12:04 AM
BR subwoofer design question? Helix Subwoofers 2 1st August 2001 02:23 PM
