Line-Level Passive BSC for CHR70
Old 6th March 2011, 01:37 PM   #11
liasom is offline liasom  United States
liasom's Avatar
Originally Posted by planet10 View Post
Without going back and reading the article, the caps purpose is to take the circuit out at high frequencies, lifting the top of a speaker that is a bit soft on the top. CHR certainly doesn't need help there.
dave
Yeah, everything I listened to came off as a little bit obnoxious with the top lifted.
I also used The Edge to determine f3 and that resulted in a much lower f3, 240Hz from The Edge vs. 442Hz using Rod Elliott's formula. I built that 240Hz f3 circuit, but after a few minutes of listening it was obvious that the higher 442Hz f3 resulted in an overall sound that I liked better. When I have time I'll hook up the laptop and do measurements of the drivers in the enclosures to see if what I'm hearing matches up with empirical data. What I'm hearing now sounds pretty good for the $ I've spent.
Mike
"Twelve." --Dr. Nikolai Zubritsky
Line-Level Passive BSC for CHR70Hide this!Advertise here!
Bsc, line-level or @ speaker terminals? markusA Full Range 21 1st March 2010 09:10 PM
passive line level BSC?x-overs? any pointers? mondogenerator Multi-Way 3 4th November 2009 07:33 PM
Line level passive BSC rhapsodee Multi-Way 1 27th July 2009 03:09 AM
Line Level BSC Again, adjusting dB. kvk Multi-Way 2 27th February 2008 08:14 PM
Fixed line level BSC based on Rod Elliot's circuit arjscott Multi-Way 10 8th November 2006 06:57 AM
