Old 25th February 2011, 06:18 PM   #1
Default again in shortened BIB fe206
Hi from argentina, I'm again over my delayed proyect, a short BIB with fe206e (70 inches tall)
I'm very confused about the measures of the box, 'cause I have read about different t/s parameters:
Factory parameters: Qts 0,18
Vas 54,53 L
"Practical" Measures: Fostex FE206E Fullrange Loudspeaker Driver
Qts 0,24
Vas 79,9 L
now... using both parameters in the BIB Calc. resulting in very differents measures.
with Factory data:
depth internal 12,54 inches
width internal 8,87 inches
nominal height 70,13 inches
and with de "real" parameters:
depth internal 18,18 inches
width internal 12,85 inches
The question: witch measures i must choose? factory? "Real"? intermediate values? please help me, and excuse my english. Salud!
Old 25th February 2011, 06:56 PM   #2
Scottmoose's Avatar
Always err on the side of caution & use whatever yields the larger cabinet; you can always damp out what you don't require.
Old 25th February 2011, 09:22 PM   #3
Godzilla's Avatar
Is it possible to agree on the measurements? Clicking on the link provided shows someone using the Dayton woofer tester. I am not sure who is more accurate. Without the actual measurements the BIB i would build would be based on the size of your room. If you can build the larger box then go for it. If your room would benefit from the smaller box then build that one. Either one should sound great.
Zilla
questions about shortened BIB fe206e lagarcha Full Range 6 6th February 2011 08:37 AM
shortened Half Chang minhaj Full Range 6 25th November 2010 01:56 AM
FE206 v FE207 in Sachiko aquapiranha Full Range 2 31st August 2009 12:19 AM
new FE206 kjunom Full Range 1 30th January 2006 10:07 AM
Onken box for Fe206 ... mark_titano Full Range 26 10th September 2005 10:16 PM
Page generated in 0.06705 seconds (72.83% PHP - 27.17% MySQL) with 10 queries
