Best size for full-range driver?
Old 26th February 2011, 01:32 PM   #51
rjbond3rd is offline rjbond3rd
Hi motosapien, you definitely need a filter to relieve the fullranger of the bass.
Old 26th February 2011, 02:52 PM   #52
motosapien is offline motosapien  United States
Hey thanks! I know it is a good idea in OB to prevent over excursion.
Although I'm very satisfied with my Coniston^2's (they brought me to tears last night in a drunken listening session), I'm interested in pursuing an OB project with the Alpair 7's similar to this:
http://www.diyaudio.com/forums/full-...b-project.html
I like the idea of sealed woofers because I am a bit space challenged for an H frame like MJK's OB project. Leaning towards the bi amp route too though plate amps are a possibility.
It's time for me to take the plunge and download some speaker design software so I can better understand this hobby. A woofer box that does 40 to 150hz, a high pass and a low pass should not be insurmountable for a neophyte. I did note however that Planet 10 has box designs for CSS's line of woofers so it may not be necessary to re invent the wheel.
Old 26th February 2011, 05:23 PM   #53
sprinter is offline sprinter  United States
I'm interested in the same arrangement (FR on an OB with a separate helper woofer). What is the least obtrusive filter arrangement one could get away with? Is it really necessary to filter for both drivers, or can you just hi-pass for the FR and leave the woofer alone? I'm just trying to minimize the crossover business if that's possible.
Old 26th February 2011, 05:51 PM   #54
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
If you are willing to into your HF amp, the least obtrusive is to shrink the size of a coulping cap to create the appropriate HP. If not willing, then a single cap on the input that creates an appropriate HP in conjunction with the amp's input impedance.
The LP XO is less audible. A 1st or 2nd order PLLXO can usually be implemented, and typical IC active XOs aren't to bad if well exectuted.
A PLLXO on top and something like SY's Acheron XO on the bottom, would be high on my list.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th February 2011, 01:21 AM   #55
I probably misused the term obtrusive, but I just meant a way that would have the least negative impact on the sound. Passive crossovers have such a bad rap but I've heard a few negatives about active XO as well.
Intuitively, I like the idea of the drivers being driven separately with a crossover device like this one Pyle-Pro PPCX2 2-Way Active Stereo Crossover PPCX2 B&H Photo in between because of the high degree of control you have to experiment with. I'm also thinking about using a couple of Tripath chip amps in this arrangement which would keep the costs down. I don't mind coloring the spectrum with EQ and such if I like the sound better. But, I don't really know the in's and out's enough to know what works and what doesn't.
What do you think about that idea with woofer-augmented FR-on-OB speakers?
Old 27th February 2011, 06:00 AM   #56
ra7 is offline ra7  United States
For crossing full range drivers to woofers on OBs, there is nothing better than NP's FirstWatt B5 active crossover. They are available now from Lowther America. They are basically active filters placed between buffer circuits.... superb sounding and way better than any other active solution.
Another option is the MiniDSP. It is really flexible and easy to use.
Old 27th February 2011, 04:47 PM   #57
The final pieces are falling into place. Thanks.
I find it very interesting that people are willing to spend $1500 on a crossover specifically made for OB's. As a newcomer, that tells me that OB is not just about economy and simplicity, but about sound quality as well. Alas, this option is too costly for me but the MiniDSP looks interesting.
Any other active crossover suggestions are welcome.
Old 27th February 2011, 08:37 PM   #58
Bobby Dipole is offline Bobby Dipole  United States
An extended range 12" is one option I've considered. Do you think your cabinet would benefit from a bass-tuned port? Or does it have one I don't see?
I'm a dummy when it comes to speaker design. I don't know the difference between ported and bass reflex, are they similar? Jensen called this cabinet their type "D" bass reflex. It's 31"x28"x13". There is a substantial rectangular opening just below the driver, otherwise the enclosure is sealed. You could easily blow out candles in front of that rectangle!
Best size for full-range driver?-jensen-jpg
Bobby Dipole
Old 28th February 2011, 03:52 AM   #59
Bobby Dipole
Very cool looking. Keep them. The bottom opening looked sealed up on the pics is why I asked. Others here can explain how this cab works better than I.
Old 28th February 2011, 04:56 AM   #60
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
I can . Speaker emits forward . Back wave is limited by cabinet
Best size for full-range driver?Hide this!Advertise here!
best full range driver cheerio Full Range 21 8th August 2010 04:08 PM
full range box size when using a subwoofer pforeman Full Range 27 22nd March 2009 10:27 AM
full range low cost and small size driver availability in Mumbai cutesound Multi-Way 1 14th October 2006 03:16 PM
Full Range Driver PassFan Full Range 4 18th November 2003 03:28 AM
Copyright ©1999-2017 diyAudio
