Hi everyone,
this is my first time here so be patient/forgiving as you've probably seen loads of geeks like me before. Basically I like sound, not from a technical point of view but a physical one. I like the sensation and emotion you can have with nothing but vibrating air since I'm 11 or 12 and this has led me into a long audiophile journey during which I've been gathering ideas, material and a perpetual thirst for new experiments. I've owned for a while now a pair of Fe126e in a small vented box and at first, I didn't like them at all because I didn't know they were supposed to be broken in for ages. As we moved from a flat into a new house, I had a new room for my daily work, which needed to be equipped so I pulled out the fostex from the closet and hooked'em to a Lyngdorf TDA2200 to make them a bit more linear. There was no revelation as they were still not broken-in, but I listen to music all day long, every day, and something started to happen, that wasn't there before, and I listened more carefully. A few weeks later I'm totally addicted and I've already ordered a pair of Saburo's from a German woodworker as I'm too lazy/busy to build'em myself. Now the question is: as a true audiophile I'm always dreaming of the next project, even if the current one is unfinished. I own a pair of Supravox 215-2000 and I wonder if they would fit in a Sachiko enclosure ? Any slight non-linearity could be corrected via the DSP's. That's it, thanks if you've read so far. Pierre-Antoine |
#2 |
Here are the specs for the supravox:
215-2000 Specifications Efficiency 1 W/1m at Fs 99 dB Fs 47Hz Frequency response 50 à 20kHz Re 4 ohms Impedance 4 ohms Qts 0.23 Power max. RMS 20 W Qe 0.24 Weight 7.1 kg Qm 8 Suspension 5 plis papier Vas 121 L Linear excursion 10 mm Bl 6.5 Magnet diameter 3.5 kg Cms 1 Magnetic field 2.1 T Mms 7g Diameter HP 224/237mm Sd 283 cm² Frame thickness lu 10mm Diameter fixation holes 227 mm Diameter drilling enclosure 212 mm Depth HP 147 mm |
#3 |
Same in french:
Sensibilité 1 W/1m à Fs 99 dB Bande passante 50 à 20kHz Impédance 4 ohms Puissance max. RMS 20 W Poids 7.1 kg Suspension 5 plis papier Excursion linéaire 10 mm Aimant Alnico 3.5 kg Champ magnétique 2.1 T Diamètre HP 224/237mm Epaisseur saladier Alu 10mm Distance trous de fixation 227 mm Diamètre percage enceinte 212 mm Profondeur totale HP 147 mm Fs 47Hz Re 4 ohms Qts 0.23 Qe 0.24 Qm 8 Vas 121 L Bl 6.5 Cms 1 Mms 7g Sd 283 cm² |
#4 |
Hello,
it would be an superb driver for a bass horn like my BASSTUBA, a need of a serie LCR between 2-6 kHz, but for the normal DIY too high priced.
http://www.hm-moreart.de |
#5 |
Well, my general rule is that a horn loading cabinet should have a driver with a low Q and large BL (powerful magnet). This is a gross oversimplification, but is something at least to get you started. Your driver appears to be in the ballpark, so perhaps it might be worth a try.
#6 |
Hi
I'm now in contact with Scott as it seems the Supravox's and Sachiko's are a total mismatch. I'll be more than happy to share about the project if we give it a go. |
| Supravox 215-2000 EXC field coil speakers (pair) | xcortes | Swap Meet | 1 | 12th January 2011 08:24 PM |
| Supravox 215-2000 EXC OB, Tribute autoformers and Visaton TL16H for sale on Ebay | ligascon | Swap Meet | 0 | 24th February 2009 02:04 PM |
| Thoughts on Supravox 215-2000 EXC or PHY-HP? | Nielsio | Full Range | 10 | 14th February 2009 08:04 PM |
| Supravox 215-2000 OB pair for sale | mattattnet | Swap Meet | 1 | 13th August 2008 12:14 AM |
| Supravox 215 and backhorns | jsb | Full Range | 11 | 15th June 2007 05:47 PM |
| Page generated in 0.08206 seconds (79.45% PHP - 20.55% MySQL) with 10 queries |
