hello..mi name is pablo and live in santiago , chile.
how is the best alternative in driver fullrange for the BLH/fe 126e enclosure. the market in chile not have a fe126e driver... greetings ..and excuse me "SPANGLISH" |
#2 |
The one and only
What do you have?
#3 |
i have only the BLH enclosure for the fe126e ...i need a driver...in madisound the fe126e driver its discontinued.
#4 |
Your English is fine, don't worry. The Fostex speaker has a low Qts which makes it suitable for horns. Try to find a driver like this would help. Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#5 |
The one and only
I meant, what drivers are available to you?
#6 |
#7 |
Get 126en
#8 |
well, you could try the 3.5" peerless tg9 (with copper cap) , but some don't like the fiberglass sound.
"The Vifa/Peerless TG9 is a very dynamic driver with very good detail. It has the best sensitivity out of this group, it gets loud with out a lot of power needed. Cross it over at 250@24DB or higher and it starts to shine. Good space and strings instruments sound very nice on this one also. This one sounded good out to around 8khz, but I would keep it around 5-7khz, depends on who is listening. The problem I had with this one is, it was to in your face. I just couldn’t get it to smooth out like the other drivers in the group. I thought it was going to the RS100 that I would have this problem with, but it was this one. This one seem to have the best attack and decay in the great." I've wanted to try the the tc9 (same copper cap and less expensive) coated paper. If I remember this is also known overseas as the f35. I've seen a little hash 1-3khz on a waterfall and it was commented as a tiny bit hazy. "The Vifa/Peerless TC9 is just smooth and accurate and laid back. This should be a Dynaudio driver. Cross it over at 250 or above @24DB and she comes to life.... But because it is so smooth for some it may be a little dark, but not to me." both excerpts from RS100, TG9, TC9, L3 and 830986 review. - DIYMA.com Norman |
| Page generated in 0.08841 seconds (74.86% PHP - 25.14% MySQL) with 9 queries |
