Old 23rd February 2011, 01:55 PM   #1
Default Full Range driver - 5.1 setup possible?
Hi All,
So, I've been thinking and searching hard on a new speaker setup ... I was thinking of building a surround system with Zigmahornets + FE103's ... plus a sub from KEF.
I've been internet hunting and not found a thing like this... But I thought it may work - any ideas?
As for a reciever I was thinking of getting a NAD (local shop here sells end of line NAD products near 1/3 of original price)...
O yeah - why - because I have some DVD-A discs (I got a SACD / DVD-A player from the said NAD shop - €99 reduced from €399 - very nice)
TWEETERS - nearlly fogot -is it worth (possible) adding tweeters to this concept (in my mind I was thinking tweeters in the front L+R Ziggies)
Any ways - what you think guys (and gals)?
Old 23rd February 2011, 02:07 PM   #2
Speakerholic
Cal Weldon's Avatar
Nothing wrong with the idea but I am wondering why you might wish to have such a large cabinet for the 103's if you are planning to use an auxiliary woofer. Those cabinets are intended to squeeze as much bass as you can from a small driver with the intent, I must assume, to eliminate the need for the extra woofer. The tweeter idea is purely subjective. Try them without first.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 23rd February 2011, 02:21 PM   #3
Hm, thats true - the reason I came up with this was:
1. At the moment I dont have any cabinet, and I would like to build my own, so I may aswell build the ziggy as its easy.
2. Its convientently floor standing - no mounting etc... and holds the speakerz at just above ear height
3. They look nice
4. I was guessing, if each component in the setup was at its best, the end result would be pretty good (my logic: If 2 ziggies are good, then with 4 or 5 I would be surrounded by good)
I guess that sub would just be used for the rumbling earth shattering bass during films (As musically I quite like the ziggys on their own - they dont need a sub) - this was jsut to 'feel' the base during explosive films.
Thanks!
Old 23rd February 2011, 02:33 PM   #4
hm is offline hm  Europe
hm's Avatar
Default penguinpoo
Nothing wrong with the idea but I am wondering why you might wish to have such a large cabinet for the 103's .
i agree with Cal,
i would prefer a small bookshelf horn like my FLUTE down to 100 Hz,
in your case the sub has a hard work to get the adequate SPL,
better take two.
http://www.hm-moreart.de
Old 23rd February 2011, 02:47 PM   #5
Originally Posted by hm View Post
i agree with Cal,
better take two.
Interesting... whats SPL?
So the flute is designed to reproduce down to 100Hz? After that I am assuming the sub will pick up?
At the same time I'm also very new to all this!
Thanks,
Richard
Old 23rd February 2011, 04:29 PM   #6
chrisb is offline chrisb  Canada
If by NAD components you mean a surround AV amp/receiver you'll likely have more than enough power on tap that unless room is very large, high sensitivity needn't be a priority.
(SPL= Sound Pressure Levels / "loudness" )
Do you already have the FE103s on hand? If not, the Mark Audio drivers are definitely work considering.
For a smaller budget, consider the CHR or CHP70 in Pensil enclosure for L&R mains, small (5.5 litre) sealed center, and Alpair6 M or P for surrounds. For a bit more ambitious project, the Alpair 7 for the front row are very nice (center will need to be a bit larger)
From the point of view of placement, Ziggies might not be the best idea for surrounds - something small enough to easily be mounted in the geometrically right locations with wall brackets sealed makes more sense.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 23rd February 2011, 04:34 PM   #7
frugal-phile(tm)
planet10's Avatar
Except, because it wasn't really "designed" it doesn't get much, if any, more bass than, say, something like the Solo 103.
The concept of FR for HT is a fine one. Keep your amp in mind when you choose drivers.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd February 2011, 04:50 PM   #8
hm's Avatar
Hello,
further info for the Flute look here,
with measurements, german feedback, plan:
Flute
may be goo.. translate helps
Old 23rd February 2011, 08:20 PM   #9
dave
Well the amp will most likely be a NAD av/amp reciever (something like a T755 or what ever end of line NAD they have at the time, see: NAD Electronics :: T 755 A/V Surround Sound Receiver )
Asides from that whats FR and HT?
I like the look of the FLUTE that was mentioned - but appears it requires a lot of specific woodwork with specific angles (at the moment I dont have a workshop, so I'll have to give my local wood selling company a series of pieces I need, so complicated angles etc... are definatly out...) :-(
Old 23rd February 2011, 08:28 PM   #10
Ahhh... FR = Full Range... whats HT (I just got it now!)
Best full range driver? markusA Full Range 102 6th March 2011 04:05 AM
No-Name full range Driver ArjenShenzhen Full Range 13 18th August 2008 12:19 PM
full range ht setup help kazoo Full Range 18 17th November 2007 03:19 AM
Full Range Driver PassFan Full Range 4 18th November 2003 03:28 AM
Advice on full range enclosure for 5.1 setup CDJ Multi-Way 3 21st January 2003 05:28 AM
Page generated in 0.11644 seconds (81.37% PHP - 18.63% MySQL) with 11 queries
