Through a stroke of luck I was able to acquire a pair of FE206E and FE206ESR.
Now the big question: What does the collective wisdom say about the enclosure that is recommended for the ESR ? You can see the the plans for the enclosure here Or should I wait for the build of the C-horn I am attempting in a few months? |
#2 |
Just saw that the link goes nowhere ... here is the correct link: http://www.madisound.com/pdf/fostexd...206esr-rev.pdf
#3 |
Hello,
for such a double pair, i would prefer a double horn like my SAXOPHON and RDH20 for max. SPL and best soundstage and lowest membran movement. Front driver the ESR and the invers back driver the 206, take view on my HP
http://www.hm-moreart.de |
#4 |
I helped a buddy of mine build a pair of the described Fostex BLH a few years ago. Well, since I only cut the materials for him and he completed the fabrication I definitely got the light duty - these are a pig to build. The unfortunate part is that they had more than a bit of coloration.
If you have another enclosure design in mind, I'd give the project some time to percolate in your imagination.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#5 |
Hello,
"a bit of coloration" that why the presschamber and the first meter is made of the wrong material, in my case i use soft fibre until the 80´s, this stop colarations above ~100 Hz and specially above ~320 Hz because you reduce the 1 and 2 sound particle velocity
#6 |
My bad I was unclear. I did not and do not intend to put them into the same enclosure. there will be one pair with the 206ESR and one pair with the 206E
#7 |
Hello,
sorry, may be my solution would be better than the standard Fostex, if you look at the 206E measurement by selbstbau.de you see it is difficult to fill it up to ~1000 Hz by the bass horn, and the baffel size will reduce soundstage a lot.
#8 |
I had my 206esr's in the Fostex 208 Sigma cabinet and thought they worked out quite well. Tried the regular 206 in them also, in fact I've had many different drivers in those 208 boxes and they all sounded good, even the little Dayton RS100.
Just once I wish someone would call me "Sir" without adding, "you're making a scene" |
#9 |
Huh? I am sorry I missed that the first reading over it. Must have been the meds they put me on when I was half way successful cutting off my finger with the table saw.
What exactly are sounds particles? I didn't know that sound now has a dual nature just as light. Can you 'splain? Maybe better in German: Ich war mir nicht bewusst dass sound jetzt auch partikel character ganz wie Licht hat. Was bitte sind "sound particle"? |
#10 |
Hallo,
ich meine die Schallschnelle, dort wo die Luft die höchste Molekülgeschwindigkeit hat, an der 1/4 und 3/4 der Wellenlänge. 100 Hz ~85 cm, 340 Hz bei 25 + 75 cm, deshalb den ersten Meter des Horns Weichfaser gekapselt, ist auf meiner HP alles beschrieben.
http://www.hm-moreart.de Last edited by hm; 24th February 2011 at 06:26 AM. |
| would fe206esr work in fe208e sigma enclosure | tiverson | Full Range | 25 | 19th May 2012 12:03 AM |
| Finished FE126e BLH Enclosure. Damping required? | fantom_circuit | Full Range | 7 | 31st October 2009 11:23 AM |
| Fostex Fe103e blh recommended enclosure frequency response | spacemen12 | Full Range | 5 | 9th June 2008 10:41 PM |
| Damping enclosure for FE206ESR recommended horn | no xo | Full Range | 6 | 13th April 2006 07:24 PM |
| FE108ES Recommended BLH Type Enclosure ???? | vexator | Full Range | 5 | 3rd April 2006 12:19 PM |
| Page generated in 0.11072 seconds (81.57% PHP - 18.43% MySQL) with 11 queries |
