I want to mate a tweeter with my drivers for casual listening with better dispersion all around the room, with the option of turning it off for hotspot listening.
So I'm after something relatively cheap, and something that only uses a cap for x-over. Also I want it to be seperate from the main speaker so it cant be a big horn. I probably want to cross relatively high, like 6 or 8Kh, so I'm out of the range where phase differences has huge importance. I have my eye on the following: - Apex Jr. ribbon tweeter. Very cheap and small, but the opinions seem mixed. I'm tempted to just try it, but it does take some effort to get the thing set up... - Hi-Vi RT1C-A more pricey with very nice horizontal spread I'm told but nonexistant vertical. How does this gel with a fullranger, and how do you make the x-over? I a simple cap enough? - Or how about the Monacor RBT-95SQ a bit cheaper than the HiVi. Is it any good? Input and suggestions would be greatly appreciated. I know similar threads have been done before, but they didn't turn out anything useful, to me at least. Last edited by Squeak; 22nd February 2011 at 08:29 PM. |
#2 |
a few thoughts:
I've used the Apex Jr tweeter with very underwhelming results - the little Audax from Steve was much nicer. You'd probably want something with at least the same sensitivity as the FE126E, i.e. 92dB or higher. I guess the vagaries of international marketing/distribution are a factor, but the Monacor Ribbon looks to be priced at 34pounds, while the HiVi and Fostex FT17H which is also worth looking at are within about $1.50 US from each other at $36.65 and $38.20 each (Madisound) A single cap of approx 3mF would give your filter a 6KHz knee, but with something like the FT17H, you might want to tame its sensitivity by going a bit higher and using the filter's slope for additional attenuation. Start with a handful of cheap .47mF mylar caps and add in parallel until you can hear more than you want from the tweeter, then insert a higher quality part of the next smallest value. Not very scientific, but it works.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#3 | ||||
Edit: Just looked up the FT17H. It looks very good, with almost perfect specs. Wonder why I never seen that before? My only worry is that it's a horn, so how's the directivity? Also forgot to mention the Fountek NeoCd1.0 1.5. It's shorter than it's bigger brother, so it must have better horizontal dispersion. How does it compare to the aforementioned HiVi and how easy is it to x-over? I read that many ribbons need more than a simple cap and an l-pad. Last edited by Squeak; 23rd February 2011 at 07:18 AM. |
#4 |
Hi
what do you think abaut this guy: http://www.tymphany.com/files/BC25SC06-04%20Rev1_0.pdf also known as vifa ht25 HNF/4 look at zaph's tests: http://zaphaudio.com/tweetermishmash/ and compare this test: http://zaphaudio.com/nondomes/ very nice little tweeter below 20.-€ is a test worth.
Regards Jörn Last edited by joern; 23rd February 2011 at 01:15 PM. |
#5 | ||||
![]() that I preferred to the $5 ribbon ![]() Quote:
#6 |
Well from what I can see the Vifa ht250 HNF/4 and the Fostex FT17H actually seem to have very similar directivity measurements (if they are to be trusted that is). So I guess it down to those two. The ribbons don't seem so hot after a bit of research.
So which one sounds the best? Which one blends the best with the driver in question? The Vifa is only 4 ohm how would one go about putting that together with an 8 ohm main driver? From what I can see you either get 12 or 6 ohm in serial or parallel. Is this correct and which one is the best option? |
#7 |
Have used FT17h extensively.
Great tweeter when crossed over high (the higher the better, really). In practice, the HF dispersion is OK if not outstanding and not as good as most smaller domes, or ribbons. If you are within about 15degrees they are fine and they still sound good out to 30degrees, just a bit soft in the very top. The off axis responses are very smooth and surprisingly artifact free, just down a fair bit. Very cheap for the performance on offer and sensitive enough to keep up with most things even if response shaping is necessary. |
#8 |
frugal-phile(tm)
12-16kHz probably more appropriate
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
Thanks chrisb and blakkshepeaudio, you've been very helpful.
But remember what I'm trying to achieve here. Maybe I should ad two caps plus switches, to be able to switch between low and high cut-off for extra "sparkle" in hotspot listening and dispersion in walk around/guest mode? Last edited by Squeak; 24th February 2011 at 08:58 AM. |
#10 |
Hi
this is a very nice made "add on" für fullrangers: AddOn They just have a capacitator and volume control... well made. In this outfit you habe to pay for it.... so maybe the luxury version for x-mas... the simple version: try 1 to 2,2µF (it's a 4 ohm speaker) and a resistor something between 1 and 4,7 ohms and listen, change, listen...
Regards Jörn |
| FS - Focal TC90K Tweeters MATCHED PAIR Tweeters Mint Condition Unused. | Julss | Swap Meet | 1 | 20th May 2010 03:45 PM |
| BIB for FE126E | blasko | Full Range | 2 | 31st August 2007 04:23 PM |
| Tweeter for FE126e? | klocwerk | Full Range | 10 | 6th August 2007 10:29 PM |
| Yet another Fe126e mod! | dfreemansc | Full Range | 46 | 29th January 2007 03:54 AM |
| Fostex FE126E | Harderror | Full Range | 11 | 28th April 2006 05:05 PM |
| Page generated in 0.12797 seconds (82.50% PHP - 17.50% MySQL) with 10 queries |
