was planning on a voigt pipe, now not so sure. - Page 6 - diyAudio
Old 28th August 2011, 12:39 AM   #51
Alright thanks dave, I think I'll take my chances with getting my dad to use a router to attempt to countersink the driver
Also, I don't fully understand the angled interior bevel. How can you screw the driver into the enclosure after effectively thinning what it's being screwed into
Old 28th August 2011, 01:14 AM   #52
frugal-phile(tm)
planet10's Avatar
The MA baskets are very open at the back so you can get reflections from a vertical wall on the cutout. You can bevel just that part not near the screws. If you built with ply like we do, what is leftover provides enuff meat for the screws.
If you want to go nuts something the heads in the direction of all-out (see picture) works too.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th August 2011, 03:48 AM   #53
ok, driver holes are cut and routed out, i'm going to bevel the inside edges tomorrow.. after that, i only have the interior baffle to make. getting closer!
Old 29th August 2011, 12:47 PM   #54
gychang is offline gychang  United States
pictures please
Good sound from Davis, CA
Old 29th August 2011, 08:57 PM   #55
Maybe when my hands stop shaking from rasping so much! Hahaa
Old 1st September 2011, 05:40 AM   #56
mondogenerator's Avatar
Default this is probably the only time i can get away with saying this....
I have a dremel for routing/shaping the rear of a cutout, but i have in the past used a coarse rash and dare i say it? even a Bastard file every now and then...less woodworking and more wood abuse
P10 states about the MA drivers having very open backs, which is true, but in contrast to some Neo drivers which are very open, In my experience, the MA drivers are open but transversely rather than axially, with respect to the cone, so naturally and unfortunately reflections will occur. unless rounded off the inner edges have a profound affect in these cases.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 1st September 2011, 05:43 AM   #57
frugal-phile(tm)
planet10's Avatar
If you get the back of the cutout at an angle (we do 45 degrees) then waves traveling sideways get reflected towards the back of the box and not right back thru the cone.
dave
Old 3rd December 2012, 11:33 AM   #58
balerit is offline balerit  South Africa
balerit's Avatar
To me the TQWP is the nicest sounding loudspeaker that I've heard and love mine.
voigt pipe new design? zycomatique Full Range 4 20th July 2010 06:00 PM
Voigt pipe as a TQWT Keriwena Multi-Way 5 21st June 2010 10:17 AM
Voigt Pipe is looking for new home mkapszewicz Full Range 9 21st December 2009 02:17 PM
w15cy in a voigt pipe sergiof Multi-Way 16 28th August 2009 11:58 PM
Folded Voigt Pipe Ropie Full Range 18 2nd November 2005 03:31 PM
Copyright ©1999-2017 diyAudio
