was planning on a voigt pipe, now not so sure. - Page 3 - diyAudio
Old 24th February 2011, 09:34 AM   #21
frugal-phile(tm)
planet10's Avatar
Russell,
Here is an ML-Voigt for the EL70.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th February 2011, 06:13 PM   #22
Thanks, I'll start building on monday, expect pictures in a new thread soon
Old 11th March 2011, 04:10 AM   #23
Planet 10, could you explain to me what looks like some sort of interior baffle? Pictured here: Click the image to open in full size..
Neither my dad or I could figure it out, as it doesn't appear on any other part of the plan, or have any sort of dimensions attatched to it.
Thanks, and sorry for bumping the thread.
Russell K
Old 11th March 2011, 05:28 AM   #24
mondogenerator's Avatar
i would suggest that this part is probably an internal brace, and as such trimming to fit may be required hence the lack of dims....
if im wrong im sure someone would correct my assumptions
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 11th March 2011, 06:29 AM   #25
frugal-phile(tm)
planet10's Avatar
Neither my dad or I could figure it out, as it doesn't appear on any other part of the plan, or have any sort of dimensions attached to it.
Russell K
Sorry Russell. to easily understand what that from what was predented you have to have had the context of my other designs/drawings. That bit is a holey brace that ties the 2 sides together. Placement is not supr critical, and some consider the holey braces optional.
Since i did the 1st pass i posted above, i've been working on the plans for Bob, who is adding it to his kit list (email m if you'd like a copy of the work in progrss). The visualization below should help.
The driver brace is indended to drain energy from the driver to the back of the box.. it should be tight against the back of the driver magnet.
dave
Old 11th March 2011, 02:46 PM   #26
Godzilla's Avatar
How did u calc the slot?
Old 11th March 2011, 05:05 PM   #27
frugal-phile(tm)
planet10's Avatar
same area/length as pipe
dave
Old 15th March 2011, 03:21 AM   #28
alright thanks planet 10, those 3d images help a ton.
Russell K
Old 27th April 2011, 07:11 PM   #29
zman01 is offline zman01  Bangladesh
Hi Russel,
Did you build the ML Voigt?
-Zia
Old 28th April 2011, 05:44 AM   #30
hi Zia,
I'm in the process. Basically I have all the major pieces cut and ready for construction and the drivers are ordered/en route.
I'll update this thread with pictures when they're done, or at least mostly assembled.
- RussellK
voigt pipe new design? zycomatique Full Range 4 20th July 2010 06:00 PM
Voigt pipe as a TQWT Keriwena Multi-Way 5 21st June 2010 10:17 AM
Voigt Pipe is looking for new home mkapszewicz Full Range 9 21st December 2009 02:17 PM
w15cy in a voigt pipe sergiof Multi-Way 16 28th August 2009 11:58 PM
Folded Voigt Pipe Ropie Full Range 18 2nd November 2005 03:31 PM
Copyright ©1999-2017 diyAudio
