Old 21st February 2011, 06:55 PM   #1
Default Best 4" with tubes, staying simple (BR) ?
Hello again,
Just shifting to a new thread to have more focused answers (my previous thread "Markaudio or 4"TB to replace FE103e with 2a3 SET?" may invite too diverse answers), so :
What do you think is the best low cost 4" driver with a simple enclosure (BR, want to stay simple) and using tube gear ? ex : TB W4-1320, CHR 70, CHP70/EL70, FE103eN, CSS FR125...
My main interest is it stays easy on the ears : no bright or zippy or peaky please. I may use Zobel and BSC to improve things.
For those who has tried several of them, could you write a few comments on each one or perceived differences ?
Thanks in advance !
Old 21st February 2011, 06:57 PM   #2
Send a message via Skype™ to Rullknufs
I don't know if the EL70 is bright, zippy or peaky but i really do like it.
Old 21st February 2011, 07:54 PM   #3
BudP is offline BudP  United States
BudP's Avatar
My Alpair 7 set from Planet 10 is exceedingly flat, without any hint of zippyness or peakiness. It is in a Fonken style cabinet so the bass is very satisfying, in an informational sense. Only a light amount of bass pressure though. Mids are incredibly clear as are the frequency extensions. It is an EnABL'd set of drivers.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 21st February 2011, 08:13 PM   #4
You might consider the Planet 10 micro tower http://homepage.mac.com/tlinespeaker...aps-150909.pdf
With two EL70 wired in series they present an 8 ohm load. I used a 68uF cap across the second driver to filter out the highs and it worked great. I think I would locate both drivers on the front if using the cap. You'll be surprised at the bass these can put out with a proper cabinet.
Old 21st February 2011, 08:19 PM   #5
chrisb is offline chrisb  Canada
how many "tube watts", or more importantly - size of room and listening levels?
I have several ranging from 3or so of the 2A3 to approx 15w in Tublelab SimplePP/EL84, as well as several pairs of Mark Audio drivers systems.
As much as I love the sound of the 2A3 & EL34SET, they simply run out of steam with the moderately low sensitivity of the Alpairs, CHR or EL70s, (or for that matter the WR/FR125) but the EL84PP works very well indeed with a pair of the EL70 Microtowers mentioned elsewhere. A very simple build and the Castle top version is not a floorspace hog, but does need some clearance on on the rear / side walls.
For flea-watt power, the 4" full-range driver I'd recommend would be Fostex FE126E, but for full effect it really wants a BLH of some type - BIB, Frugel, B Busch, Scott Lindgren Saburo / Valiant, etc. I've heard examples of all of these and not all are complicated builds, they do pay the price of physical size. NSTAAFL
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 21st February 2011, 08:27 PM   #6
Monte Verdi's Avatar
My vote is for Alpair 7 as the clarity and smoothness with tubes is mind blowing. I have been using them with a customized Scott 222C which puts out 18 watts per side and the 7's sound glorious. Now I hear the 7's EnABL'd take it to the next level. Also, have not tried SET amps with this yet though I cannot imagine them sounding anything less then amazing. Here is link to my review of Alpair 7 in a OB configuration.
Alpair 7 Revisited review
Ramon
Last edited by Monte Verdi; 21st February 2011 at 08:28 PM. Reason: spelling error
Best slam and punch in the bass for hifi (not PA): TH with 15 OR 2x15 BR OR 1x18 BR? pk Subwoofers 19 12th March 2011 06:24 AM
NP:"Simple Sounds Better" TGY:"Simple Food Better" Gyuri The Lounge 10 19th December 2009 09:03 PM
Need advice on notch filters or BSC for FE207 simple BR jsb Full Range 14 13th September 2006 11:42 PM
Dayton BR-1 "experiment" and review. netgeek Multi-Way 20 4th June 2004 09:08 PM
Page generated in 0.42974 seconds (1.29% PHP - 98.71% MySQL) with 10 queries
